Old 03-12-2003, 02:10 AM
Imagine Imagine is offline
Default Is it possible to save PT as a template?
In DP, you can save all your settings, and hardware as a template, so you don't have to reset them every time you use the program.
Thanks
Imagine
Dean
Old 03-12-2003, 03:15 AM
John H John H is offline
Default Re: Is it possible to save PT as a template?
It's pretty easy, more of an OS thing than a PT thing.
Create everything you need in a new session, Auxes, midi tracks, audio tracks, sends, etc...
When you're happy that's the template you want, save it, quit protools then locate the file in the finder.
get info on the file in the finder ( APPLE + i ) then click on the stationary pad option in the lower right hand corner of the info window.
This turns the file into stationary, everytime you open it, you can create a whole new session with it.
Old 03-12-2003, 01:04 PM
Dale-c Dale-c is offline
John, you know it is interesting that I got 8 stable tracks with the davec test on my computer. That would be about right for the difference in clock speed. That would come out to 50mhz per track. I would be interested to know if 500 Mhz would get ten tracks. I have 512 as you can see now but when I tested I only had 320.
Old 03-12-2003, 04:46 PM
Thanks John,
I appreciate the help.
Imagine
Dean
Unable to save as template doesthisexist Pro Tools 10 1 11-26-2013 08:50 AM
(-50) ERROR on Save / Auto Save oldrake macOS 1 10-14-2013 03:30 PM
Can't save template on PT 10.3.2 Blackers Pro Tools 10 4 12-22-2012 05:17 PM
Want to save the tracks and mixer as a template? Intuition Pro Tools 9 2 12-01-2011 10:53 PM
5.0 save/save as/new icon huh zeeman Pro Tools TDM Systems (Mac) 0 11-30-1999 08:25 AM
