Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 02-24-2024, 03:26 AM
nvtmusic nvtmusic is offline
Default avid carbon with wavelab
Hi , will the carbon interface work with wavelab ?
(os 13 m2 max) new to mac and was using wavelab on my pc
was going to install it on the mac - thought i'd check first - thanks for any help
mike
Old 02-24-2024, 03:36 AM
dominicperry dominicperry is offline
Default Re: avid carbon with wavelab
I can't see any reason why it wouldn't work. You will get high-ish latency (3-4ms in/out, 7-8ms roundtrip) and no use of any of the DSP or remote preamp controls. But it should work otherwise with the Carbon Core Audio setting. You will also be limited to a reduced number of inputs and output (something like 24/28) rather than the 56/84 available in Pro Tools with Carbon (see discussion here: https://duc.avid.com/showthread.php?t=423713)
I would just try it, if you already have a license.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 02-24-2024, 08:09 AM
Thanks !
Does Avid Carbon work with Avid S1? YellowPine Pro Tools | Carbon 4 12-16-2023 11:15 PM
Avid Carbon frazzz Pro Tools | Carbon 11 11-03-2023 10:38 AM
Pro Tools | Carbon & Carbon Pre compatibility with AVID S4 Control Surface [email protected] Pro Tools | Carbon 9 09-14-2023 10:36 AM
FS: Avid Carbon plunderpot Buy & Sell 0 08-01-2023 09:38 AM
Can Avid Carbon(PRE) be used together with HDX ? pm mastering studio Pro Tools | Carbon 3 10-21-2022 05:17 AM
