Old 04-14-2022, 10:51 AM
Zergei72 Zergei72 is offline
Default DIGI-002 Windows Vista 32Bit
002 Rack giving me Code 10 / Code 45 in device manager .
Acer Aspire 7720Z Laptop Integrated Ricoch 1394 - Chip .
Tried changing to OHCI Compliant, no differ .
All other devices installed correctly, nothing strange in device manager, though WIFI not installed .
On macOS Big Sur platform see, this ...
https://duc.avid.com/showthread.php?t=419597
The unit seemed to work like a miracle, but now this ...
- Z -
Old 04-14-2022, 11:00 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: DIGI-002 Windows Vista 32Bit
IIRC, A Texas Instrument firewire chip is needed. Also, possibly the power harness.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 04-19-2022, 01:11 PM
This is likely a dead end, but... see if you have the option of a TI Compliant firewire driver and try that. Having said that, consider a few things:
1-What version of Pro Tools LE are you trying to use?
2-Does this error happen with Pro Tools open, or does it never open?
3-according to the specs I see on line, this laptop is woefully under-powered for Pro Tools(Core2 Duo 1.46GHz cpu)
4-what drive are you wanting to record to? The specs show a 5400 rpm internal drive which is too slow.
5-I also see this laptop uses integrated graphics. With the Pro Tools version that runs on Vista, integrated graphics was usually a show-stopper. Plus, it shares RAM with the cpu, which pretty much ruins whatever performance was even possible.
Sad to say, but its probably time for a new computer and interface(there's little point in spending a dollar on hardware this old)
Pro Tools 9 and Windows 7 32bit sunking3 Windows 2 08-14-2011 04:42 PM
Help to get Mbox 2 running again with Vista (32bit) Anders S 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-18-2011 07:32 AM
Using more than 4gb RAM on vista/win7 32bit OS BingeBuddy420 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-16-2009 03:47 PM
mbox 2(Vista 32bit) asio driver install Numi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-08-2008 01:31 PM
digi 002 windows vista drivers? babymanuel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-18-2007 07:52 AM
