Old 12-24-2021, 08:58 AM
roderickelms roderickelms is offline
Default Pro Tools 9 + Command 8 or other?
I'm still occasionally using Pro Tools 9 on location (MBP; OS10.6.8) and I'm thinking about picking up a fairly cheap Command 8 controller. I'm sure that the Command 8 works fine under PT9, but am wondering whether there is anything else to consider. I assume that most recent controllers will not work with PT9. If anyone happens to have knowledge of this, I would be grateful to know.
www.masterkeyboards.co.uk
Old 12-24-2021, 12:00 PM
Default Re: Pro Tools 9 + Command 8 or other?
Indeed, most of the crop of newer controllers aren't going to work. Command 8 is actually quite a good little surface. If you don't need 8 faders, the original Presonus Faderport is quite decent(still using mine on PT2021.12). Other option that MIGHT work(if you can get the proper drivers) would be the old Mackie controllers, but anything that has a HUI mode may also work(again, subject to a compatible driver). All things considered, I would still go for the Command 8 if you need all its function, or the old Faderport for its small size(with good functionality).
Old 12-26-2021, 01:29 AM
Thank you for your helpful reply. I think it sounds risky to buy and try anything more recent, so I'll give the Command 8 a go.
[IMG] code is Off
Pro Tools 12 and D Command? Inglesworth Pro Tools 12 4 12-27-2019 04:30 AM
Pro Tools, HUI, and Command 8 justinhill Pro Tools 2018 7 09-09-2019 09:31 AM
Pro tools command 8 davyjune87 macOS 2 03-12-2014 03:44 PM
MTB command with pro tools LE?? kostantinos MIDI 0 03-01-2008 06:57 AM
Command tools KEY? groan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-23-2005 08:02 AM
