Old 12-21-2021, 06:07 PM
basslik's Avatar
basslik basslik is offline
Default Mbox 2 Pro and Pro Tools 9 installation
I bought a Mbox2 pro and a used PT9 License for my daughters to use and learn recording. I have no idea how you turn on this little puppy. Where's the on and off power button ?.
I've plugged it in to my Mac pro VIA firewire and power chord. and all I see is blinking yellow.
I tested it and unplugged my 003 console and used my firewire cable, although I did not install the drivers because I didn't want to install the Mbox on my existing setup.
I'm embarrassed asking and thought there would be a power button in the back, and the Mbox manual stated so, but that was a different model I guess.
Also with no power on at all it's blinking yellow even when the computer is off >? THANK YOU AND MERRY XMAS
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 12-21-2021, 06:10 PM
Top Jimmy's Avatar
Default Re: Fell Embrassed (Mbox2)
As I recall, you do need to install the driver to get everything to light up correctly.
James Cadwallader
Old 12-21-2021, 06:32 PM
And now you are into do you have a driver for this old interface that is compatible with your operating system?
Maybe you have that all sorted out. But if not I would forget this old stuff, the Focusrite 2i2 is the canonical beginners interface, and at least on current computers, you are likely much better off starting there than with old Avid/Digidesign interfaces.
Old 12-21-2021, 08:39 PM
basslik's Avatar
I have gotten her basically the same setup I have. Mac Pro 2010 / Mbox2 pro, OS Mt. Lion & El Capitan running PT 9
I figured to get her something that I already know well and can help her over the phone along the way.
I'm just stumped there is no power switch and the unit blinks yellow even when the computer is off (strange). I did look up the manual and doesn't say much about powering on and powering down.
I will be able to retrieve the driver from my Avid account I'm sure.
Old 12-21-2021, 09:45 PM
Sardi Sardi is online now
1. There is no power button on an MBox 2 Pro.
2. You shouldn’t be using the ext. power supply if you’re plugged into your MP’s FW port. That will provide the power required for the interface. The ext. power supply is only required for 4 pin FW connections.
3. How do you plan on testing anything if you don’t install the drivers?
4. The blinking light is more than likely related to the power supply issue I pointed out above.
Old 12-21-2021, 11:36 PM
Ben Jenssen's Avatar
I have my old mac pro 3,1 sitting in a corner, connected to the mains, and a Apogee Duet connected via firewire, and its LED is blinking. Always did.
Old 12-23-2021, 01:14 PM
basslik's Avatar
Default Re: Mbox 2 Pro and Pro Tools 9 installation
Thank you folks very much. You folks are awesome.
Sardi I guess I should have known that too. The interface is a Xmas present and couldn't hook it up until tomorrow and I figured since I bought the Mbox I eBay I wanted to make sure it powered on at least before I wrapped it for Xmas.
I went ahead and bought her a PT10 license version as well since that is what I used too, and I really like the responsiveness better than my 2021.3 setup.
Installation problems with Pro Tools 8.0.4 LE with Mbox 3 Mini. The Confused Monk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 06-28-2011 12:52 PM
Pro Tools Developer and MBox 2 Drivers installation issues dilig0 Virtual Instruments 0 11-10-2010 12:42 AM
Installation of Pro Tools 8LE Mbox family T&M Prod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-23-2009 01:00 PM
MBox 1 Installation Corrupts MBox 2 Installation. Any Ideas Short Of Reinstalling OS? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-01-2009 07:03 AM
Pro tools le7.4 installation error...now mbox won't respond. billforrbill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-02-2008 12:51 AM
