Old 02-03-2014, 10:58 AM
shultzee13 shultzee13 is offline
Default Recording Clean sound while monitoring distorted guitar
Brand spanking new 11R user here. Must have missed this in the manual..... how do I go about recording clean uneffected guitar tracks in pro tools while hearing distorted of the same guitar in my headphones at the same time? I must be missing something here.
Sorry for the newb question....but I am just that.
Thanks
Old 02-03-2014, 11:22 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Recording Clean sound while monitoring distorted guitar
For the effected track you want input "Eleven Rig L\R"
For the dry guitar you want the input to be "Guitar"
You'll probably want to mute the dry guitar track while recording
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 02-04-2014, 07:21 PM
gseshleman gseshleman is offline
Next time you create a new session, try the "Re-Amping" template
under the Eleven Rack category. you should find it very helpful as they've included comments on the tracks.
esh.
Old 03-06-2014, 07:13 PM
Ok guys my mistake. . I am only using the 11R as a guitar preamp not as a recording module. My Module is the fast track solo cause I am using PT Express.
Is there a way to split or have the distorted track come out of the left of the 11R and the clean out of the right and go into channel 1 and 2 on the solo?
I need to record the clean signals for reamping but monitor (headphones) the distortion while I am recording the clean tracks at the same time.
I'm I stuck recording the distorted and then going back and recording all the clean tracks along to the dirty track?
The guitar Y cable I bought is a NO go. It's causing all kinds of high end signal presence when recording.
Thanks.
Pro Tools 11.3.1 & 10.3.8
Interface - Focusrite Clarett Pre2/Clarett Octopre
Computer - Mac Mini 2.5 GHz Intel Core i5, 16GB
OS - Yosemite
Monitors - Yamaha HS8
Old 03-07-2014, 09:34 AM
Benoni's Avatar
This is so much easier to do with the Eleven Rack as your interface. You signature says you have PT11, is there anyway you can use that instead of PT Express?
If not, one possible solution is to use the Output to AMP. Set the source to the input of the chain which is guitar only, and run that into your Fast track.
If the Fast Track has SPDIF, that would be a much better way. Use Split IN/OUT on the Eleven Rack.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 03-07-2014, 09:47 AM
Yes sir I do use PT 11 but our guitarist in Florida (we're in Texas) uses PT Express. Sorry I didn't clarify that.
I am helping him on his new 11R.
We really appreciate all your help on this.
OS - Yosemite
Old 08-04-2014, 03:49 PM
norman bataille norman bataille is offline
hi guys i have pt express with fast track duo , am trying to record the guitar without effects and in fact it sounds clean when playing but when i press record the guitar is sounding distortioned like electric am usin a godin multi acs , please help me up thanks in advance
Old 08-04-2014, 04:14 PM
YYR123's Avatar
YYR123 YYR123 is offline
You really should start your own thread bro !!
also include your list of equipment computer software version etc.
Daniel
record guitar and microphones to my Pro-tools HD and while recording monitoring it vi vingador6 ICON & C|24 3 08-22-2013 05:04 PM
Extremely Distorted Sound When Recording Through Mbox 2 TheEvilCow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-27-2010 11:49 PM
recording distorted guitar? 21fm Tips & Tricks 11 07-02-2005 08:02 PM
Distorted sound in recording tracks TDub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-09-2004 04:01 PM
heeelp, distorted sound while recording... BesnikB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 12-18-2003 02:15 PM
