Old 01-06-2013, 12:33 AM
sekie sekie is offline
Default AUX TRACK gets no signal
Dear all,
I hope someone could help me on following issue:
Would like to add REVERB to an audio track (L-voc) via a stereo AUX track
SETUP:
Send (A) on VOC track is sending to BUS 1-2
AUX track in/out receives from BUS 1-2
DVERB is in the insert for the AUX TRACK
L-voc armed
The AUX track gets (fader is up) no signal sent from L-voc at all ... ?
I checked the In/out settings and all is correct
I run the 002 via PT8LE
Could someone give me a hint where the problem comes from ...
many thanks
Serge
Old 01-07-2013, 03:36 AM
Default Re: AUX TRACK gets no signal
Bump ...
Is there anyone who could jump in here, please?
thanks
Serge
Old 01-07-2013, 03:54 AM
SKI's Avatar
SKI SKI is offline
So you are trying to hear the Reverb on the incoming signal while recording?
Not really the most desirable thing to do because of latency but;
-Do you have the Send fader turned up?
-Is LLM turned on or off?
Record something then see if it sends the audio that is recorded to the Reverb during playback.
URBAN MUSIC-
(Hip Hop and R&B)
Old 01-07-2013, 07:30 AM
jmitchell1532 jmitchell1532 is offline
Make sure your Send's fader is also set to a decent amount.
Jon
HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!)
Old 01-07-2013, 03:34 PM
Regarding that^^^^ there is a preference setting for added sends snapping to either -0 or all the way down. Maybe grab a screen shot and upload to photobucket, then link to here so we can actually see your assignments.
Old 01-07-2013, 10:40 PM
zedhed's Avatar
zedhed zedhed is offline
Yup, most likely you're send fader is turned all the way down. Click on the send (in your case, A) tab to make the fader appear and adjust accordingly.
As Albee said, if you don't want the fader to be automatically down each time you create a send, adjust in preferences menu.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 01-08-2013, 12:38 AM
Dear all,
thanks for yr input
Of course the fader was up ... that was the first thing I did when I created this setup via the AUX track
However the solution to make it work is: to "UNTICK" LLM
So a big thank you to "SKI"
kind rgds to all
Serge
Old 01-08-2013, 09:03 AM
Ah yes...LLM. The manual is pretty clear about LLM mode disabling sends and plugins on any track that is in record ready(you can tell as the little "buttons" that represent sends and plugins go blue). BTW, when they are inactive, they go grey. Let the learning begin (IOW, don't get discouraged by all this. There's a lot to learn and you'll get there in time) If you hate reading manuals, try searching youtube for "pro tools and ________(insert issue here)" without the quotes as there are lots of tutorials(some better than others). Another great source of videos is pro-tool-expert.com(toss them a donation as it will be well worth it).
Old 01-08-2013, 09:23 AM
SKI's Avatar
SKI SKI is offline
The good thing is once we got the 32 buffer setting the use of LLM wasn't as critical as it was prior to that.
Remembering the days of saying get a mixer to monitor your playing seems like a very long time ago.
URBAN MUSIC-
(Hip Hop and R&B)
Old 01-08-2013, 09:51 AM
I also record at the 64 buffer setting(LLM has not worked on my rig for 2 years). No complaints about latency there either.
No Mic Signal Through Audio Track jbax98 Pro Tools M-Powered (Win) 1 12-26-2010 09:58 PM
No signal on audio track Blackout25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-12-2010 07:13 AM
Signal loss on an aux track?!?! Charles D. Ballard Post - Surround - Video 3 03-16-2007 10:52 AM
aux track signal but no midi signal? elv1s1sal1ve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-06-2005 07:18 PM
Signal Level of the track? King Kong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-24-2003 06:00 PM
