Old 05-08-2012, 08:06 AM
novellorecording novellorecording is offline
Default How to set up a live audio feed for a radio broadcast
We are fairly new to Pro Tools. We are running Pro Tools 9 on a PC and we have the MBOX Pro 3rd Gen. We have been recording on our system for several months. Now we have a situation where we are going to be on a live radio show. We want to run intruments and vocals through our pro tools set up and connect to the DJ's set up. It is an internet radio program and is run right from the DJ's computer.
Any advice on how to run connections? How do we set up a session? Do we have to record to get our sound out of the monitors? Can we get sound out of the monitors for the musicians and also have a separate output running to the DJ? We have many many questions and want to know the best and easiest way to get what we need.
The set up is a vocal mic, acoustic guitar running directly into the Mbox, Bass and keyboard also running right in and a percussion player who will be miked, prefferably with 2 mics, but we will work with one if necessary.
Does anyone have any experience with Pro Tools and a set up similar to this? We'd greatly appreciate any help or advice.
Thanks
Old 05-08-2012, 09:32 AM
browniespeaks browniespeaks is offline
Default
I would suggest you skip the DJs streaming software and run everything into a Barix Exstreamer. The Barix will stream to just about any computer with an internet connection. it's easy to setup it doesn't lose it setting if/when something plugged. There at for sure other ways to do this, but I've found running the Mains and streaming a stareo mix is the easiest and least taxing on resources.
Sent from my SGH-T769 using Tapatalk 2
Clifford Brown III
Brown Audio Solutions & Services
www.brownaudio.com
Old 05-09-2012, 08:27 AM
daeron80 daeron80 is offline
Default Re: How to set up a live audio feed for a radio broadcast
Set up just like you would to record the group. If you don't wish to record the performances, you could use Aux tracks instead of Audio tracks. But audio tracks in record monitor would work just the same.
Run the main outs from the Mbox to the DJ's sound card or audio interface input. It may require a cable you don't have, such as dual 1/4" to stereo mini. It depends on what the DJ has for inputs. Special cables like that can be purchased from Radio Shack.
You may be able to monitor from the DJ's speakers, or you may need to send each track both to your monitor system and to his sound card/interface. That can be done by holding down the Start key while choosing an additional output with the output selector of each track.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 05-09-2012, 09:13 AM
Default
Man please if your going to do this live make sure everything is stable a crash will put strange soundson the air instantly. Maybe do a run of dress rehearsals.
Clifford Brown III
www.brownaudio.com
live video and audio feed? mr.armadillo Post - Surround - Video 20 12-24-2013 11:41 AM
PT Live Broadcast audiowave productions VENUE Live Sound Systems 11 10-28-2010 06:00 PM
Live broadcast mix ? priorytools Pro Tools TDM Systems (Mac) 0 10-05-2008 10:00 AM
Mic for Radio Broadcast and an Audio Book? Kustoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-23-2005 09:49 PM
Editing interviews for radio broadcast greytail General Discussion 9 03-09-2004 09:48 AM
