Old 04-14-2012, 04:01 PM
awritersparadise awritersparadise is offline
Default Eleven Rack window on Pro tools only available at random
Just purchased the Eleven rack this week.. installed the drivers..
the manual says within pro tools I can just go to window>>eleven
from there I should see the software that controls the eleven..
It didn't show up.. I rebooted a few times.. one time, it showed up.. I figured problem solved.. I rebooted again.. it's gone.. and won't come back.
confused! thanks for any tips/help on this one.
Old 04-14-2012, 04:13 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Eleven Rack window on Pro tools only available at random
The Eleven Rack is connected to the computer via USB correct?
Is it directly connected to the computer or on a hub?
Have you tried a different USB port?
Have you tried a different USB cable?
Have you tried trashing databases and preferences?
What version of Pro Tools?
What Firmware is on the Eleven Rack?
http://www.youtube.com/watch?v=sFclFceQDg0
If firmware is version 2.0.1, was it pre-installed or did you buy the ERXP and update yourself?
Did you recently update Pro Tools?
When the screen does come up, and if you have the ERXP, did it properly display all the Eleven Rack items?
If not, then you should run the first section of the ERXP again
http://elevenrackusers.blogspot.com/...howing-in.html
Windows XP, Vista or 7? or OSX?
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 04-15-2012, 11:05 PM
Your reply was very helpful. I followed the instructions on the website you gave, and it worked like a charm..
Thanks a bunch,
S
Old 04-16-2012, 06:27 AM
jopheza jopheza is offline
What did you do? seems like i'm having the same problems
Old 04-16-2012, 06:40 AM
Sorted it. apparently you're not supposed to disable other soundcards!
http://avid.force.com/pkb/articles/e...oting/en367487
No Eleven Rack Control Window With Pro Tools 11 turbolx5oh Eleven Rack 15 12-08-2014 03:28 AM
Eleven Rack blank window with Pro Tools 10 jamieguitar Eleven Rack 9 07-21-2013 12:02 PM
No Eleven Rack window in Pro Tools 10 kenneho Eleven Rack 2 07-14-2013 01:15 PM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
