Old 09-23-2011, 07:02 AM
Fleishman Fleishman is offline
Default Side chain bus is disabled
I'm not able to use a side chain bus in any rtas plugin in Pro Tools 9. When I click the "key menu" I can't select any bus as a source - it just won't open. I can only choose from the interface list...
Can you help me?
Old 09-23-2011, 02:50 PM
BillDog793 BillDog793 is offline
Default Re: Side chain bus is disabled
Just something to try...when you go to I/O, under the bus tab, are there any busses set up? You could also select all, delete all paths, and use default, to bring them back. The only down side to trying that, is you will have to re-do the buss sends. Hopefully this helps.
Old 01-02-2024, 11:05 PM
Fegley890 Fegley890 is offline
I know that I am very late to this party. But I just had a similar issue and would like to post for all those who follow.
Protools only sidechains in mono. Make sure that when you create a stereo bus you also create 2 mono sub-paths. If you only have stereo busses, they will not show as available in the side chain menu.
[IMG] code is Off
Is it possible to side-chain an EQ? Herkimer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-03-2009 06:00 PM
Using Side Chain with outboard? jimbojimbo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-24-2008 03:08 AM
How do I set up a Side Chain junglelabs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-30-2007 10:49 PM
Side Chain ByPass Tips & Tricks 1 05-08-2007 12:33 PM
A better way to side chain? studiojb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-24-2007 04:40 PM
