Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
  #21
Old 09-09-2011, 05:53 PM
sunburst79 sunburst79 is offline
Default Re: recording from ADAT
A standard optical ADAT cable is all you need. You can find them at Best Buy, Sweetwater, Guitar Center etc. Sometimes referred to as a Toslink cable in the consumer world. Don't be tricked into buying some type of premium optical cable like Monster since its digital cable and it's only transferring zeros and one's. After you have transfered the track's into Pro Tools make sure to set the clock back to internal.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
  #22
Old 09-10-2011, 07:00 PM
violent vickie violent vickie is offline
Do I need a special cable to record via optical?
  #23
Old 09-10-2011, 10:37 PM
http://www.guitarcenter.com/Hosa-Pre...07-i1128909.gc
http://www.guitarcenter.com/Live-Wir...53-i1166800.gc
http://www.guitarcenter.com/Hosa-Sta...91-i1129172.gc
http://www.guitarcenter.com/Live-Wir...03-i1166803.gc
http://www.guitarcenter.com/Rapco-Ho...88-i1482732.gc
Most of mine are made by HOSA or Livewire. Best Buy also used to sell them under the Dynex brand. Any reasonably well stocked music store should stock the cable you need. They may called a ADAT cable, Lightpipe Cable or TosLink cable.
Scott
Core 2 Specs Page
  #24
Old 09-13-2011, 10:28 AM
Do I need a special cable?
  #25
Old 09-13-2011, 10:53 AM
No. Any of the ones I listed in the previous post will do.
Scott
Core 2 Specs Page
  #26
Old 09-14-2011, 09:50 AM
Sorry about repeating that. For some reason, I didnt see the responses to my question or my question. Maybe I didnt realize there was more than one page..
Thanks for yr help! I just ordered a Hosa Premium Optic Cable off of Amazon for $11. I'm excited to finally get all that old stuff off of my ADAT and sell that thang!!
  #27
Old 09-18-2011, 09:59 AM
I got my optical cable in the mail!
Can you attach pictures on here?
I want to attach a screen shot of my 1814 software. I will just write it out:
Under "digital port selection" there is the option of selecting
input: adat or spdif
output: adat or sdif
spdif input port: optical or coaxial
(I assume you select optical, but that did not work, maybe due to some other settings.)
Under "sync source", you can select internal, external, or word clock.
(none seemed to work)
Then, in Pro Tools, what types of tracks should I be using, MIDI tracks? Audio tracks? I don't see an input for the ADAT on Pro Tools, but when I make a MIDI track there is a Firewire 1814 input, channels 1-16.
Should I make 8 MIDI tracks and select channels 1-8?
Thanks so much for your help!
  #28
Old 09-18-2011, 10:00 AM
Also, I don't need to have 1/4" cables coming out of the ADAT into the 1814, right? All I need is the optical cable to capture the 8 tracks?
  #29
Old 09-18-2011, 11:25 AM
necjamc necjamc is offline
Correct.
  #30
Old 09-19-2011, 07:00 AM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
INPUT = ADAT
OUTPUT doesn't matter
SPDIF INPUT = OPTICAL (although you're not using SPDIF)
SYNC = EXTERNAL
Since you've changed your IO you need to rebuild the IO as far as ProTools sees it. Go into your IO settings and click the DEFAULT button. You should now see your ADAT Inputs. These will then come up as selectable on your 8-audio tracks as sources (NOT MIDI). If not, look in the manual (I'm doing this from memory) as it's all spelled out very well there.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
ADAT optical recording skirby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-18-2010 05:05 AM
Recording through ADAT port on 003 RockGod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-06-2008 10:48 AM
Problems recording with ADAT Sniperdot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-22-2007 05:55 AM
adat recording daveyajd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-27-2004 04:56 PM
Simultaneous Recording PT &ADAT Llanito Pro Tools TDM Systems (Mac) 0 11-27-2001 05:07 AM
