Sonic No Noise on G4 HD 4
Again I have searched and can't find any answers.... I am trying to use Sonic No Noise "audiosuite" declicker. It tells me it's going to take a while, then after about 2 minutes, It gives me an error and says the audio file is much too large for the poor little machine to deal with. It is an audio file that is about 2 seconds long. Any ideas? PT 7.3.1 G4 DP 1.25 HD4accel OSX Tiger
bookerv12 |
Re: Sonic No Noise on G4 HD 4
if your trying to process a file with the "D" setting as opposed to the general setting you will run into this issue. The "D" setting is for extremely small sections of audio, I think 10mm or less. Once you surpass this amount of time you will run into problems. The manual covers this topic.
Cory Rizos, CAS Re-recording Mixer/Sound Designer Montreal, Quebec http://www.imdb.com/name/nm0007185/ coryrizos.com |
Thanks Cryos,
Have been through the manual 10 times. It was working fine for a few years. None of the audiosuite plugs would work. Reloaded plugin software and ProTools. Same problem. Did it again. Now it works. Thanks
bookerv12 |
Strange indeed. At any rate it seems the issue is resolved.
Cheers
Sonic No-Noise on G5 PCIE | JJC | Pro Tools TDM Systems (Mac) | 3 | 05-08-2006 08:57 PM |
Sonic No-Noise | cjguitar | Post - Surround - Video | 0 | 06-29-2004 04:34 PM |
Sonic Noise Noise Manual? | Great Divide Studios | Pro Tools TDM Systems (Mac) | 2 | 06-08-2003 04:31 PM |
Sonic No Noise for Pro Tools | spigots | Pro Tools TDM Systems (Mac) | 10 | 02-16-2003 06:22 PM |
Sonic solutions No-Noise | tnie | Pro Tools TDM Systems (Mac) | 1 | 04-23-2002 09:09 AM |
