Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 06-13-2009, 10:02 AM
Dozerbabar Dozerbabar is offline
Angry PT8 constant -6101 cpu issue - HELP!
Ok, this is just crazy...
I started a sesson, all was working out fine, and suddenly, boom, the cpu hit the ceiling and the sound dissapeard. I've tried every step possible in problem solving, including changing every cable, but the problem is still there. I even tried record on three separate discs, I've tried resetting the Lightbridge, re-installed the drivers on the Lightbridge, installed the lastest cs-patch for PT, trashing prefs and so on. I've even tried two different Lightbridges!!
After a restart PT might work for 5 minutes before it happens again.
Running PT8cs3 (I installed cs3 after the first round of errors...)
Leopard 10.5.6
Macbook Pro 15" c2d 2.16 with 3 gb of ram
Profire lightbridge with lates firmware-updates and bootloader
I'm stuck here. Need som help.
www.molotow.no
Old 06-14-2009, 11:38 AM
Default Re: PT8 constant -6101 cpu issue - HELP!
A little update:
I did a clean install of the whole mac yesterday. The only additional plugs and add-ons I installed (which all should be qualified) was:
- Music production toolkit 2
- The Massey plugs
- Mellowmuse ATA
- SPL Free Ranger
We recorded for a few hours today when I got the CPU-error (6101) and after that: No sound! I restarted everything, but no change.
So we had a backup mac that I installed PT8 on and this worked flawlessly for the rest of the session (5 hours or so). We even recorded on the internal harddrive as this mac only has one FW connection.
www.molotow.no
Old 06-14-2009, 06:25 PM
Skyflash Skyflash is offline
Are either your Bluetooth and/or Airport turned on?
You could also try disabling Spotlight as I believe it needs to be off to run PT.
Old 06-15-2009, 04:36 AM
I'm using a bluetooth mouse, always have, don't see why that should be causing the problem. Always had the airport on aswell.
Spotlight is disabled :)
I've tried to run the Lightbridge on a separate bus and all was well for a few hours, but as soon as PT decides to f&ck with me I need to shut the mac down, restart the Lightbridge and turn everything back on to get sound.
Restarting PT does not help. Resetting the Lightbridge does not help. Everything needs to be shut down.
DIGI: Anything?? I CANNOT work like this!
www.molotow.no
Old 06-15-2009, 11:11 AM
maxpidgee maxpidgee is offline
anything?? ok, FOLLOW THE DIRECTIONS!!! turn off blue tooth, airport, etc....
www.myspace.com/maxpidge
Old 06-17-2009, 08:38 AM
Not to be an ass here Max, but I have NEVER had any problems with bluetooth and airport on. I need the bluetooth for my mouse anyway, so there has got to be another solution?
To do a little update I did a pretty long mixing session yesterday without major problems. I got one error, had to restart PT = no sound. Had to restart the whole system to get it back. After that it was no hassle. Didn't record anything though.
But it seems like the performance in PT8 MP is not as good as it was when I used 7.4 LE. Is there anything to that or is that another "bug" in my system?
www.molotow.no
Old 06-22-2009, 10:27 PM
tekis tekis is offline
I like "Bad Reputation"! Good old hard rock. My LB only works on its OWN FW buss--no sharing! I actually use a USB 2.0 drive for my audio. I have a Mac Mini w/one FW port. I'm running MP PT8 as well. I never update these things once they start running well. Did you do some kind of update to your OS before seeing any problems? Good luck, I hope you get it sorted out.
Old 06-23-2009, 04:15 AM
Thanks, I think that track turned out pretty cool
I read a lot on M-audios forums as well. It seems like everything works now with the LB on its own FW bus. I have tried a USB audio drive as well and no problems so far.
Thanks for helpful advice, tekis
www.molotow.no
Old 06-29-2009, 06:45 AM
Damn, back in the same old cpu-spikes loop.
This is unbearable!!
Any suggestions, Digi?
www.molotow.no
Old 06-29-2009, 09:58 AM
DigiTechSupt's Avatar
Have you tried it with bluetooth disabled, as asked for previously?
We know you may not have had problems before, but you're having them now and bluetooth is known to be problematic at times, so best to test without it and see what happens.
Avid Audio Tech Support
Support FAQ
ERROR -6101 constant bakerja Pro Tools 11 11 11-08-2013 07:27 AM
Constant -6101 errors while recording bleen macOS 21 05-29-2013 05:17 PM
PT8 constant -6101 cpu issue, Let's do something mistlabz Pro Tools M-Powered (Mac) 47 08-31-2009 05:15 AM
Constant error messages (-6101), (-9128) MdotCash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 42 07-14-2009 03:15 PM
Constant -6101 errors mpeddle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 03-10-2009 09:03 AM
