Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 09-17-2008, 10:42 AM
Scott Goldberg Scott Goldberg is offline
Default Re: Pro Tools is unable to communicate with HUI.
SWEET! Good Luck! Ask for help anytime. E-mail [email protected] or http://goldrecordings.com
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
Old 10-01-2009, 09:03 AM
4times4mil 4times4mil is offline
I had this problem for a couple days...I found out that it was happening because the session I was having the problem with was created elsewhere and not in my system...so I created a new session and imported the tracks in and the problem disappeared.
Old 03-14-2012, 11:07 PM
mswan23 mswan23 is offline
Cool Re: Pro Tools is unable to communicate with HUI.
Hey guys!! To solve your problem disable your BCF2000 back to None in your peripherals settings then exit out of pro tools. Make sure you are in Baby HUI Mode. Then Right click your PRo TOols Desktop Icon and click run as administrator. Then enable your BCF2000 again in the Peripherals and it will work fine! Good Luck!
Old 07-17-2012, 07:54 AM
richmond910 richmond910 is offline
Has anyone fixed this problem, I’m running M Powered 8 In the peripherals under "received from" The "Project mix Controller" is not shown, it does show "Project mix External" in the "send to" It shows both controller and external
I’m running a Dell T55oo quad Intel 2.4 on windows 7 SP1
HELP
Old 09-01-2014, 10:46 AM
Sagar19723 Sagar19723 is offline
"Run Pro Tools as Admin". This should solve the HUI protocol Issue. I had a similar one with Novation Impulse.
  #16
Old 09-01-2014, 10:49 AM
"Run Pro Tools as Admin" should solve the HUI Protocol Issue.
  #17
Old 05-04-2015, 03:37 AM
miro3 miro3 is offline
Hi Everyone
to make your V-Control works , Your Mac & iPad Should be connected to the same Wi-Fi
Enjoy :)
  #18
Old 01-29-2016, 04:18 PM
charlesrickard charlesrickard is offline
UPDATE!!!!!!
If you have not already, make sure what you are using meets HUI protocol. For me, it was as easy as switching my peripherals back to "none" and simply creating an instrument track and choosing a plugin. Now I am able to play MIDI into ProTools no problem.
Pro Tools is unable to communicate with M-Audio Keyboard mstreacy Windows 27 11-08-2017 08:22 AM
Pro Tools unable to communicate with HUI MCU. earshatter Pro Tools M-Powered (Mac) 2 11-17-2016 12:56 AM
Pro Tools is unable to communicate with HUI milkman Pro Tools M-Powered (Win) 4 05-20-2008 02:27 PM
Pro Tools unable to communicate with control 24 stipe ICON & C|24 2 09-20-2006 11:40 AM
Pro Tools is unable to communicate with HUI Gilfigga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 09-22-2003 06:57 PM
