PT 4.7 HD vs. LE vs. M-Powered (Software)
Is there anywhere I can go to find out what the differences in features are between the different versions of the software? I have heard that LE and M-Powered are the same.
Thanks, Steve |
Re: PT 4.7 HD vs. LE vs. M-Powered (Software)
No one?
Steve |
Reasons to buy M-Audio:
Can be cheaper than LE. You may already own an M-Audio interface. More interfaces are available to work with M-Audio. M-Audio interfaces work with other programs. Reasons to not buy M-Audio: There are some limitations in the software, it's apparently not exactly the same as PTLE . However, it's very close. You get no Free Software Bundles when you purchase like you do in LE. Things that don't work with M-Audio: DV Toolkit, Digi Translator.... It was made to expand PT's user base on the low end. M-Audio is apparently going to go heavier on the MIDI side of things. Hope this helps. |
Thanks man - Much appreciated...
Steve |
Difference between LE and M-Powered software | Aliweasel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 04-07-2007 02:39 AM |
Will 002 work with M-Powered software? | stoomey | Pro Tools M-Powered (Mac) | 1 | 11-07-2006 10:32 AM |
Why no Software Upgrade PLUS for M-Powered? | shu | Pro Tools M-Powered (Win) | 0 | 12-16-2005 08:29 PM |
PT LE & PT M-Powered Software Difference | New Dimension Studios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-27-2005 08:30 AM |
Can I run my m-powered software without hardware? | Flailey | Pro Tools M-Powered (Mac) | 3 | 10-17-2005 09:14 AM |
