Old 12-08-2007, 06:29 PM
MK25toLife MK25toLife is offline
Default Keep getting the same error message dealing with iLok
I keep getting this error message after installing Pro-Tools M-Powered 7.1. "This version of Pro-Tools M-Powered requires authorization to run, but no iLok can be found. Please install the iLok for this software.
I have tried to synchronize and identify my iLok but my iLok was not recognized at all. I have installed the driver and client helper from the iLok website and I still keep getting the same error message. PT worked fine on my old computer, I just got a new one and started having all these problems and I have no idea what's wrong. Can someone help me out?
Old 12-09-2007, 10:36 AM
RichrdC RichrdC is offline
Default Re: Keep getting the same error message dealing with iLok
I had the same problem and beleive it or not, in my frustration I moved the iLok from one USB port to another and the problem went away!! I don't know why but it worked for me... I've got nothing technical for you though.. Good luck
Old 12-13-2007, 03:26 PM
I've tried all the possible USB ports on my computer and still no luck. I also tried to install on my friend's Mac and no luck either. Anyone!?!?!?
Old 12-15-2007, 12:11 PM
StavrosSound StavrosSound is offline
Did you download and install the package from PACE, then insert your iLok and let the "new hardware" search for the correct drivers... in which case it found the drivers on the PACE install?
Sort of convoluted, but thats how I got my iLok to function.
"White noise- the birth cry of the universe."
IMDb Credits
Old 12-19-2007, 08:41 PM
Unfortunately none of the tips listed on here has worked, any other suggestions?
Old 12-19-2007, 10:13 PM
spkguitar's Avatar
If your ilok isn't' being recognized/synchronized at ilok.com, that means one of 2 things;
  • the client software is not installed, or not installed correctly (this could definitely be the case if you have tried to install it several times)
  • the ilok is defective
If you know anyone else with a Pro Tools system that uses an ilok, you can test to make sure the ilok isn't defective on their system. If you don't know anyone else with Pro Tools, you might be able to take it into your local retailer and test it on their demo system.
Otherwise, I would contact ilok.com for further assistance.
iLok License Manager - LICENSE TRANSFER ERROR MESSAGE jzacks524 General Discussion 6 06-26-2013 05:43 PM
iLok error message Cejis33 Windows 0 04-22-2012 12:07 PM
dealing w/iLok when upgrading CCL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-15-2010 06:08 PM
strange pt8 ilok auth missing message? crizdee Pro Tools TDM Systems (Mac) 2 02-07-2009 03:39 PM
ilok account message audiocase Pro Tools M-Powered (Win) 2 12-14-2006 04:55 PM
