Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 11-14-2007, 10:26 PM
JrummerJ JrummerJ is offline
Default Re: CPU Overload (error 6101) on intel macbook pro
So, a follow up. I've tried a few things:
Reinstalled OS 10.4.9, PT 7.3.1 cs5, M-Audio driver 1.8.2. Still exp problem.
I bought a siig fw 400 expresscard to get the external hd on a different bus. CPU usage seemed better, but still got the error.
Tonight I copied over a few sessions to the internal drive, and was unable to get the error on a session with 12 tracks including: 9 audio, EZdrummer, Xpand, and a master fader...even adding up to 16 D-verbs and lowering the buffer to 128! Oh yeah, and airport and bluetooth were on, too.
At this point, I would have to chalk it up to either the drive or the inability of the mac to have multiple firewire devices connected at the same time. Both of these are a little hard for me to accept. The same drive worked flawlessly on my AMD desktop even chained through the 410. As far as the mac goes.....it should just work
Next steps: borrow another firewire drive to try, or just get a glyph or Lacie.
So, what do you guys think?
Thanks for those who tried to help.
J
Old 11-15-2007, 09:10 AM
bradch00 bradch00 is offline
I would try another drive, I mean you've really done almost everything else. I don't know what chipset WD puts in their drives, but if you do try another one, make sure it has a compatible chipset (Oxford 911 for FW400 drives). I know people have had success with the additional FW card, so this really does point to a drive issue.
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 05-29-2008, 03:54 PM
brian5258 brian5258 is offline
i'm having the same problem on a brand new mac book pro intel 2.4ghz on 10.5.3
i'll have like two tracks open and i'll get that error randomly. the cpu usage has never gone above 25%
Macbook Pro 2.4ghz 4G ram OSX Leopard 10.6 003r+ PT 8 LE
PC - GIGABYTE GA-X58A-UD3R, i7-950 Bloomfield 3.06GHz, 6GB CORSAIR XMS3, EVGA GeForce GTS 450, Intel X25-M 80gig SSD, Windows 7 Pro
Old 11-11-2008, 12:53 PM
milan cutlac milan cutlac is offline
Hi Brian,
Did you solved the problem ? I'm using PT since 3-4 weeks now and I cannot get rid of the same error under same circumstances : a 2 track session. I read about less powerfull Macs than mine that work very well with PT, so this is very confusing.
Regards,
Milan
MacBook 2.4 Ghz/2 Gb Ram/160 Gb Hdd
Leopard 10.5.4/ PT 7.4.2
MBox2 Mini
Old 01-14-2009, 03:16 PM
axisrecording axisrecording is offline
Same Problem here -just got a macbook pro, after killing my powerbook. running 7.4.2cs or whatever is current. current everything. checked through all the docs on install. been through a lot of threads, I sent a client home today it was so bad, Trying to make a living. DIGI?? I had better performance on an old G3
  #16
Old 01-14-2009, 03:38 PM
DigiTechSupt's Avatar
We're going to need a lot more info - see the Help Us Help You thread for details...
Avid Audio Tech Support
Support FAQ
  #17
Old 01-15-2009, 04:35 AM
Wolfgang Eller Wolfgang Eller is offline
OK, next one with the same Problem.
Recording 2-8 Tracks with a 2.2 Ghz Macbook Pro and 4 GB Ram.
7.4.2 CS2, 10.5.5, external FW 800 drive and a M-Audio 2626.
Buffer set 1024, DAE 4, no plugins at all.
I always get the message after a fresh start of the Mac within 10 and 30 minutes.
When it happened once it´s OK till the next time I have to start the Mac again.
And I´ve tried really everything.
Digi, please can you help me?
www.srs-mastering.de
Mac Pro 6.1-8core, OS 12.6, PT2023, HDX2, Sonnet Echo Express III-R, Madi Interface.
  #18
Old 01-15-2009, 09:42 AM
I'd bet money that it is because you are using an external drive @800 speed and an interface that is @ 400 on your macbook pro. There is known issues doing this, since both ports share the same bus. Try chaining your drive with a 800 to 400 cable or with a standard 6pin 400 cable if it has other ports. I put my external drive on a siig expresscard and the interface on the macbook pro port and I really only experience this problem when I load up the session with VIs, which can be resource hogs.
J
  #19
Old 01-15-2009, 11:44 AM
You can't do that. M-Audio devices are not compatible with FW800 drives. If your drive has FW400 ports, please use those, otherwise you would probably be best served by getting a Siig 2-Port expresscard and connecting the 2626 to that and the FW800 drives to the native FW800 port on the computer. Please see the M-Audio website for more info.
Support FAQ
  #20
Old 01-15-2009, 12:27 PM
OK, but why do I have the same problem with a FW400 drive?
And why do I have NO problems after the first half an hour, anyway if FW400 or 800 drive???
error 6101 cpu overload on macbook pro reddog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-25-2011 06:57 PM
CPU Overload 6101 error FutureBC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-30-2010 09:06 AM
error -6101 cpu overload peter99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-19-2010 02:28 AM
CPU Overload Error (-6101) on intel imac mack122 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-05-2007 02:12 PM
CPU OVERLOAD ERROR MacBook Pro 2.16 (intel) Help needed. Arska 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-01-2007 10:46 PM
