#21
Re: Firewire410 Problems with sound output
I had the same issue with the FW410, something about clocking to external S/PDIF seems to be "not right" with the unit, regardless of what drivers are used. The Projectmix i/o, using S/PDIF in and synced to wordclock from a Big Ben, seems to be free of that problem. I notice that when looking in the Pro Tools playback engine setup, using the M-Audio 1.7.4 drivers the highest buffer setting I see is 1024. With the 1.8.2 drivers, there was a 2048 setting available. Maybe that's a clue to some kind of error with the 1.8.2 drivers.
-Mark Mac Pro 8x2.8gHz, 4gb RAM, M-Audio Projectmix I/O, Pro Tools MP 8.0 |
#22
Going back to 1.7.4 has (so far) solved the problem here.
Greeting GS |
#23
FWIW I've been having the same problem with my Firewire 1814 and my MacBook Pro (2.4Ghz - July 2007 model). Output just randomly stops. On the audio panel I can still see level meter activity on the software return bus but nothing on the output. The only fix is to reset the 1814 from the audio panel or turn the 1814 off/on. I've been working with M-Audio support for two days and tried everything from older M-Audio drivers to disconnecting all other firewire devices on my MacBook Pro (which is laughable as I do all my recording to an external firewire drive). Nothing fixes it. Finally I'm told this is a KNOWN PROBLEM that will be fixed by the next driver update. When is that? Nobody knows! Well if it's a known problem and considering the 1.8.2 driver was released in April of 2007, maybe somebody should get on with releasing a FIX!
Until then, I guess I just have to reset the 1814 between takes in the hopes of buying myself as much time as possible between failures. Very disappointing to have something so fragile. |
#24
Well, did we pay to be beta-testers here? I just wrote this complaint to M-Audio (not that it will solve anything)
#25
Re: Firewire410 Problems with sound output *DELETED*
Post deleted by exiter
#26
I bought a macbook pro this summer and I had this problem for a short while. I am running OSX 10.4.10 and M-Audio 1.8.2, and everything is now working just fine. The 3 things that I found that may have helped were disabling Dashboard, Spotlight, and Safe Sleep.
Once these were disabled, everything has been working fine, with wireless and bluetooth turned on. Dashboard: http://www.macworld.com/weblogs/maco...oard/index.php Spotight: http://www.macosxhints.com/article.p...50504012104186 Safe Sleep: http://www.macosxhints.com/article.p...70302210328928 Good Luck, J |
#27
#28
#29
Have you tried disabling the items I mentioned above? J |
#30
PT10 on OSX10.8 - Firewire410 has VANISHED? | leonardrock | Pro Tools 10 | 2 | 03-29-2013 12:15 PM |
FireWire410...WHERE ART THOU? | spunkynuts8 | Pro Tools M-Powered (Win) | 2 | 06-01-2006 09:57 PM |
firewire410 price lowered !!! | neatguys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-28-2005 05:41 PM |
Sound output 001/ various newbie problems | junior phoenix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-11-2004 02:19 PM |
sound output problems | chagos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-28-2004 12:20 PM |
