bug report: wide meters mode
Ctrl-alt-start-clicking on the narrow meters when in "narrow mix" view causes the meters in the FIRST CHANNEL to get wider and narrower. It doesn't seem to matter which channel you click on, it's always the first channel's meters that change.
The behavior is normal when narrow mix view is turned off. Then, ctrl-alt-clicking on the wide(r) meters causes each of those meters to get still wider (or return from extra-wide to their normal wide state). Probably low priority, in the global scheme of bugs, but it seems like it should be pretty easy to fix. |
Big HUGE fat (wide) meters | Tyderian | Tips & Tricks | 37 | 12-13-2016 06:16 AM |
Any suggestion? control 24 meters dead in PT work in Vegas mode | crizdee | ProControl, Control|24, Command|8 | 1 | 03-28-2013 03:29 PM |
Grid mode, shuffle mode, spot mode and slip mode. | RogTaylor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-24-2010 10:30 AM |
FYI: WIDE LEVEL METERS | 2012 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-17-2006 11:28 AM |
Wide Meters kybd combo | SoundWrangler | Pro Tools TDM Systems (Win) | 2 | 05-18-2004 07:37 PM |
