Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
  #21
Old 05-17-2007, 08:01 AM
Diginerd Diginerd is offline
Default Re: Does lighbridge support more than 18IO with PTMP?
For clocking you don't make a cable like that.. What you need is a bunch of BNC T Pieces and some lengths of BNC terminated cable. Old School ethernet cable works well for short runs.
You plug one BNC into the Light bridge, run a cable to a T piece, plug the T piece in the back of your interface, and then the other side of your T piece you run a cable to the next T piece and so on. The last interface simply has a BNC cable plugged into it from the T piece before
http://www.edaq.com/ec10.html < The T Pieces
Here's a poor asci art diagram of what I'm talking about
<font class="small">Code:<hr /><pre>
[lightbrige]-------------- T--------------T--------------T--------------[Interface]
[Interface] [Interface] [Interface] </pre><hr />
http://www.sgnr.net
  #22
Old 05-19-2007, 08:19 PM
Sam Amato Sam Amato is offline
I've been clocking via ADAT with no problems so far, although my testing has been somewhat limited (only a few band rehearsals and one live show). It does not even seem to matter which device is the master as long as the rest are set to slave to ADAT for clock. I'm aware of the BNC T method and that was my original plan but since things are working fine with ADAT and the setup is easier, I think I'll just keep doing it that way. Would any of you recommend NOT doing this? If so I'd be interested in your reasoning.
My mobile rig:
(3) Behringer ADA8000's
(1) Profire Lightbridge
(1) MacBook
(1) Behringer DDX3216
Macbook 2GHz C2D, 2GB RAM, OS 10.4.8
M-Audio Profire Lightbridge
Pro Tools Academic 7.3.1cs1
  #23
Old 05-30-2007, 03:29 PM
5sonic 5sonic is offline
So if I go out and buy a Lightbridge and M-Powered 7.3 software today, I'll be able to hook up to an SSL Alphalink 24 channel ADA and get all 24 channels simultaneously? And this will work as long as I don't use the CS upgrade?
  #24
Old 05-31-2007, 09:06 AM
kafka kafka is offline
One more thing which I don't think has been covered yet.
IT'S MULTI CLIENT CAPABLE.
I run pro tools and cubase 4 at the same time, both with full access to all the I/O at once.
I run with 24 outs to my mackie d8b, first 8 ins back from tape outs 1-8 from the desk. Profire inputs 9-16 are connected to an emu E-Synth ultras adat outs, and finally outputs 25-32 are connected to inputs 25-32 with a single fiber looped back.
This last piece allows me to pipe audio back and forth between pro tools and cubase for live processing.
I so need latency compensation, but I work around it with track offsets
Good lord. I don't quite get why I'd want to do that, but isn't it just sick how capable this box is? It makes me want to run out and buy one - if only I had something to plug into it!
  #25
Old 05-31-2007, 10:36 AM
Andi R Andi R is offline
Thank you very much, of course this is the way to go...!
ReRecording Mixer & Venue D-Show Live Sound & Recording Engineer
www.audio-machinery.com
  #26
Old 06-14-2007, 01:19 PM
could you all please post which versions of PT you are using for this?
PTMP 7.3.1?
cs2 or not?
cs3?
Thanks a lot to all of you guys!!
  #27
Old 06-15-2007, 07:27 AM
therecordinghouse therecordinghouse is offline
how can you call this a "bug"? looks like i might be dumping my 002r...
Lynn Graber
Studio and Mobile Recording, Fort Wayne, IN.
  #28
Old 06-15-2007, 12:54 PM
hey, you have exact the same pre amps I have!!!
  #29
Old 06-15-2007, 12:55 PM
oh, and there´s no music production toolkit for MP!
  #30
Old 06-15-2007, 05:43 PM
spkguitar's Avatar
You're wrong about that. The Music Production Toolkit works just fine with MPowered.
The DVToolkit 2, on the other hand does not work with MPowered. Perhaps that is what you were thinking about?
Support Update: Avid Support Codes - Effective July 31, 2010 Avid General 0 07-31-2010 11:55 AM
can i sell PTMP 7.3/7/4 ilok license and still keep PTMP 8.0 license? edgarbc1 General Discussion 0 07-17-2010 01:09 PM
Lightbridge and 18IO wildplum Pro Tools M-Powered (Win) 5 08-07-2007 08:43 AM
OSX 10.4.2 and PTMP.... Aleatoric Pro Tools M-Powered (Mac) 1 07-26-2005 01:34 PM
