kick drum leakage! help
I'm mixing a band and have huge problems with the kick drum..
The kick drum have a leakage from the snare and hats, wich i find impossible to delete. I'm not bad at gating, but its impossible toget a good kick sound cause of the hat. If i leave the leakage there, it will make the mix muddy and uncontrolled.. one idea is to cut out one kickdrum hit and paste it to all the other hits, but it should be a easier way to do this! |
Re: kick drum leakage! help
Use samples. Download a demo of drumagog and replace each hit with a sample, or mix it in to taste.
Better mic'n technique first off. Try using a tunnel if you do not have a HOLE to put the mic it. The tunnel (blanket) will allow some coverage. Test a run through before you make the final "Let's go" and see that you are getting the transients. Bleed can be good, but isolation is always better. How large is the room? Make sure that you are not gettin flutter off the wall that is causing the mic to pick up those reflections mainly. Move the kit to a different area and try that. Soundreplace with a great kick sample.
Good luck. Doc
MONUMENT SOUND MONUMENT SOUND ON YOUTUBE Monument Sound Facebook "Changing how people hear music one track at a time" |
http://hifiat32.com |
if you have to keep working with those track, you can try gating with a side chain EQ so you dont get false opensing and you dont have to gate so hard. strip silence is very usfull aswell. |
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Try this:
tab to transient, paste a kick sample
If nothing else, notch filters can help minimize the bleed - but at what cost? |
First off, i totally agree with you guys on how to record the kick better..
but in my case, the drumset was recorded in another location without me beeing the tech. I can use a sample from DFHS and mix it in, but that will take ages to implement. (6 songs even) Unless there is an easy way to get those samples to match the original kick. Interesting suggestion sqkguitar, i'll try that out. I dont mind some bleed from the kick, but as it is now when i try to get that 'click', the snare and the hat get way to colored by the kick eq. |
You can also just use the grabber tool to slide it backwards in the session. Also, keep in mind that this technique uses two of the valuable limited 32 voices. You will most likely want to record the output to another audio track, and then deactivate the original and the trigger copy.
Kick Drum | dBHEAD | Tips & Tricks | 6 | 10-11-2011 12:01 PM |
Help with Kick Drum | torquemada | Tips & Tricks | 13 | 11-05-2006 07:20 AM |
2nd mic on Kick drum? | bigbubbaj | Tips & Tricks | 17 | 08-09-2004 05:10 AM |
60 Hz Kick drum | Brain Digger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-14-2004 10:37 AM |
Senheiser MD 421 or Shure Beta 52 for kick drum?r kick drum mic? | H-man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 08-16-2001 07:07 AM |
