Old 07-03-2020, 09:43 AM
Dphx2 Dphx2 is offline
Default Uninstall older version when updating Pro Tools 2020.5 on macOS?
I down loaded OS 10.5.5 and I'm ready to down load PT 2020.5. Should I uninstall my older version of PT first? Theres no data or songs I want to keep. New to all this.
Last edited by DigiTechSupt; 07-03-2020 at 08:04 PM. Reason: Subject updated from "Question" and moved to related forum.
Old 07-03-2020, 10:07 AM
Southsidemusic's Avatar
Default Re: Question
No olderr versions needed. Just run the 2020.5 installer and then the AIR plugins and so on and that is the steps to install.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 07-03-2020, 03:25 PM
I can't speak for Mac users, but Windows users should uninstall the old version(along with the HD driver if that option is shown) before installing a newer version. Some Windows users will likely be confused that PT shows up on the Apps & Features list, but can't be removed. The solution is one level deeper. Right-click on Start and select Apps & Features. Then in the upper right, under "Related settings" click on Programs and Features. On that list, Pro Tools can be selected(select "Change" and follow the prompts) and removed.
The same goes for Eucon software. Always uninstall the old version before installing a newer version. Any settings you changed should remain in place.
Old 07-03-2020, 05:00 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by albee1952 View Post
I can't speak for Mac users, but Windows users should uninstall the old version...
That does sound like good advice to me. But ... here's my own experience.
A year ago, I did a clean install of Windows 10 Pro and PT 2019.6 on 2 rigs. Since then, I've installed each subsequent PT version release over-top of the previous version, without first uninstalling. Worked every time - no issues. I seem to recall it even remembers my prefs. I do run CCleaner reg cleaner each time. Actually I run CCleaner and also the CCleaner reg cleaner somewhat regularly. I guess I figured if AVID needed us to uninstall first they would've stated that in the install instructions. I dunno ... I'm just glad when it all works out!
Click for audio/video demo
Click for resume
Old 07-03-2020, 06:00 PM
Default Re: Uninstall older version when updating Pro Tools 2020.5 on macOS?
And since the OP is on Mac not windows.... To make clear again... there is definitely no need to uninstall previous installs. macOS has a very nicely designed way that apps get packaged that makes this unneeded.
Old 07-04-2020, 05:11 AM
Exactly,
So to those answering PLEASE read the thread and OP posts before adding info not applicable to the questions i.e Mac vs PC - install vs unistall
This just complicate things and adds confusion and makes threads way longer than they need to be.
Thanks and have a great 4th for those who celebrate
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 07-04-2020, 06:27 AM
lae777 lae777 is offline
As stated previously, no need to uninstall older versions but, on a mac you can rename the version you are currently running, and then install the new version, so that you can have more than one version on your system, just in case you need to go back to an earlier one.
I have about 5 or 6 previous versions installed (called for example. "Pro Tools 2020.3", "Pro Tools 2019.10" etc.), which is definitely overkill but doesn't seem to affect my system at all.
Of course, since PT 2020, the workspace has changed and you need to update to the latest workspace version, so the older versions may not be totally compatible from now on.
I always back up my preferences, and other files like the workspace database and catalogues, using Pete Gates PT Prefs application, before I install a new verrsion, just to be sure.
5,1 Mac Pro, 3.46 GHz Six Core Xeon, 48gb ram, Pro Tools Ultimate 2023.6, HD Native card, Avid 192io interface, Avid 96io, Intensity Pro video card, Radeon HD 7950 graphics card, Mac OS Monterey 12.6.7.
Old 07-04-2020, 09:36 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by Southsidemusic View Post
...to those answering PLEASE read the thread and OP posts before adding info not applicable to the question...
(Ooops - sorry 'bout that)
Click for resume
What is the most recommended MacOS for Pro Tools 2020? Zak7 Pro Tools 2020 5 05-02-2020 04:20 PM
Cannot install Pro Tools 2020.3 (macOS) iz_thewiz Pro Tools 2020 1 04-06-2020 12:16 PM
Delete/uninstall Pro Tools 10.0.0 before updating to version 10.3.10? Rusty71 Pro Tools 10 3 12-06-2015 06:07 PM
Will updating Flash Player affect older version of Protools? novice12 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 02-03-2013 01:00 PM
Help a noobie: Updating older version of Pro Tools Astar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-22-2006 02:25 PM
