Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 07-10-2019, 10:37 AM
Meads Meads is offline
Default Attention Avid: "Reached max number of audio tracks" error after offline bounce
This is the second or third time I've seen this error after doing an offline bounce. The bounced file wouldn't automatically be imported to a new track as instructed, but instead I got this message.
I use PT Ultimate, the hidden tracks in the picture are inactive. I'm not even close to the maximum available tracks.
Using 2019.6 on MacOS 10.14.5.
Most bounces work fine, but some randomly do not.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 07-10-2019, 12:38 PM
DigiTechSupt's Avatar
Default Re: Attention Avid: "Reached max number of audio tracks" error after offline bounce
What sample rate are you running on?
-Tope
Avid Audio Tech Support
Support FAQ
Old 07-10-2019, 12:51 PM
You might be running on 96khz sample rate? This limits the number of audio tracks to 64.
-Tope
Support FAQ
Old 07-10-2019, 03:58 PM
I am running 48kHz.
Also I was able to import the bounced file manually to a new stereo track with no problem. I'm definitely not touching the track limit.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
"The maximum number of projects has been reached for this account" pinckneyb Pro Tools | First Discussion 11 01-19-2019 09:59 AM
"Pre-Echo" Offline bounce problem frenchman Pro Tools 2018 26 06-25-2018 08:29 AM
"The maximum number of projects has been reached for this account". kpvalentine Pro Tools | First Discussion 2 08-17-2017 06:00 PM
"Unable to bounce offline" fcamardella Pro Tools 12 6 11-25-2016 04:36 PM
Error message: "Playback has reached end of session" Wolfgang Eller Pro Tools 12 3 10-04-2015 02:13 AM
