Old 09-27-2017, 02:31 PM
pqlior@mac.com pqlior@mac.com is offline
Default Split out of (avid)multiband splitter is phasing
I'm using the Multiband splitter to feed an aux track (in my case the low-mid split) and it's phasing with the original signal. Seems like it's not being compensated properly. No plugs on it. Most of the low end disappears when I add that split channel but not perfectly out of phase.
Lior
HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 *
iPad Air/Avid control * EuCon 18.3.0.217 *
Old 09-27-2017, 02:40 PM
Ben Jenssen's Avatar
Default Re: Split out of (avid)multiband splitter is phasing
http://www.avid.com/plugins/pro-multiband-dynamics
Bottom of the page:
Pro Multiband Dynamics is not recommended for parallel dynamics processing as it can result in phase issues between the processed signal and the unprocessed signal.
Old 09-27-2017, 03:19 PM
Originally Posted by Ben Jenssen View Post
It's not the dynamics, it's the splitter and it's designed for exactly that purpose. (I think...)
It says this:
You can use Flip band processing mode for results similar to parallel processing without phase issues or having to set up parallel compression routing.
What does that mean?
Lior
Old 09-27-2017, 03:31 PM
SBP SBP is offline
Hi -If I sum all the plug in split AUX outputs and also the main output of the plug in -then invert the phase the on the main post the multi dynamics plug in =sound fully cancel.
This is on a native pro tools system.
Cheers
Bruno
Old 09-27-2017, 03:32 PM
teedeecee teedeecee is offline
Perhaps a simple band pass or HPF & LPF filter could achieve the same thing sans phase issues.
Old 09-27-2017, 03:55 PM
Cheers
Bruno
Right- So that's NOT happening on my rig. (HD native)
Lior
Old 09-27-2017, 04:10 PM
SBP SBP is offline
Is the delay compensation thingo showing green?
Just wondering if its something else in the session that is throwing things off.
My test used AUX input track as source what sort of track is your multi dynamics plug in on?
Old 09-27-2017, 04:21 PM
Yes. I'm attaching a screenshot. (and in case anyone suggests that, even with plus disabled, it still behaves this way.
File Type: jpg Screen Shot 2017-09-27 at 4.20.27 PM.jpg (18.5 KB, 0 views)
Lior
Old 09-27-2017, 04:26 PM
Drew Mazurek's Avatar
You two are talking about different things.
Take all the splits, break them out each to their own Aux Input, then sum all of them back together while putting plugs on the low mid band that you want.
This way they've all gone through the "same routing"
www.drewmazurek.com
Old 09-27-2017, 04:34 PM
Cheers
Bruno
Also- What are you referring to as the "main output of the plugin"?
The channel out?
Lior
Avid Pro Multiband Dynamics Question Cryos AAX Plug-ins 2 12-30-2015 05:20 PM
Avid Pro Multiband Dynamics Plug-in - deapth versus ratio Gm167704 AAX Plug-ins 2 02-03-2015 01:42 PM
Avid Pro Multiband Dynamics & Pro Subharmonic DHL AAX Plug-ins 25 11-24-2014 07:06 AM
AVID: Split this forum into Mac & PC soon! nob turner Pro Tools 9 9 11-07-2010 01:01 PM
D-Control 32 split or no split? Don Geppert ICON & C|24 8 01-30-2007 10:15 AM
