sends vs outputs
What is the difference between out puts and sends? Not sure when I need to use one or the other. I was watching a tut on side chain compression and noticed he used the outputs to to bus the tracks to the aux. Why would he do that and not use sends?
Re: sends vs outputs
Pretty simple, outputs are physical, directs the signal to a physical output on your interface/converter.
Sends direct signals elsewhere via a bus. The bus can be used as an input on an aux, an audio track, a compressor for sidechaining. Busses can be connected to outputs, so you can send to an output as well...
Lincoln Mitchell Pro Tools | latest Mac Mini Server | OSX | Current 16GB Ram | SSHD Apogee Ensemble Thunderbolt |
Let me try to draw you a "mental picture" (easy for me, since most people say I'm mental anyway)...
Sends, busses, and outputs in a DAW come from the terminology used in the old mixing console days. Imagine you've got a long metal box. Along one of the "long" sides you have a series of jacks. For the moment, we'll call them "input jacks". Along the other "long" side you have a series of jacks. For the moment, we'll call them "output jacks". Then, running lengthwise in the box, are several wires. For the moment, we'll call them "busses", since that's what they are. Each one of the "input jacks" has a series of switches attached to it. These switches allow you to connect the input to one or more of the busses. Since you use these switches to send the associated input to the bus(es), these switches are often labeled "sends". Some of the "output jacks" will also have a series of switches attached to them, allowing them to receive a signal from one or more of the busses (and feed the signal out the "output jack"), while some of the busses will be directly connected to a dedicated "output jack". These switches are used to connect the signal on the "bus" to one or more outputs, depending upon the configuration.I In an "actual" console (or mixer), you will typically find a record bus (used to feed a tape deck or A/D converter(s), one or more monitor busses, and one or more AUXillary busses, which are for various purposes. It's a little more complicated than this, but I've given you enough to get the basic idea. Something that is helpful is to visit a console manufacturer's website and look at the pictures while reading this, and if the site has a signal flow diagram you can correlate the things I've mentioned here with the diagram. Now, pinnacle, you are not allowed to post here any more 'cause Avid sold Pinnacle...I'm sure you understand... You failed to mention if the dude in the video was using a hardware compressor or a plugin...it does make a difference. If the guy was using a hardware compressor, he would have to send the both the "trigger" signal and the signal to be compressed to outputs so they could be used to feed the compressor. And keep in mind that in most DAWs you can name sends/busses/outputs whatever you want to, so while it may have been labeled an output, it could have actually been a send-to-a-bus...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
sends split the sound -whereas output simply bus the sound to whatever output you want
Well, I think it was said, but yeah, that will send the entire contents of the track along the bus. Had he used a send it would have created a parallel compression aux... Much of this has more to do with using axes vs. sidechaining...
Some outputs and sends were made inactive? | ZombiesAreJerks | macOS | 1 | 04-27-2013 04:26 PM |
Sends default to -inf preference...resetting all sends to 0 | Nathan W. | Post - Surround - Video | 3 | 07-15-2011 12:10 PM |
outputs vs sends for mixing down within pro tools | roark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-30-2011 03:59 PM |
Copying Sends Levels between sends | Premo | Pro Tools TDM Systems (Mac) | 11 | 09-27-2008 10:03 AM |
Sends Vs. Outputs | 3Dbuddah | Pro Tools TDM Systems (Mac) | 0 | 06-21-2003 04:28 PM |
