I DON\'T want to calibrate my room
I DON'T want to calibrate my room, but I do have a question about the actual level of the final film mix (NOT the listening level/spl). Should it be mostly around -24dB to -18dB? Where should the peaks be, at -10dB?
Re: I DON\'T want to calibrate my room
DmFisher,
If you don't you must have a very good reason that I can't seem to think of. There is NO standard to where it should sit. Only after your room is calibrated do you Mix and listen and then it's Very obvious where your levels should be. Is this a Feature Film or direct to DVD? It does make a difference. Are you talking Dialog average or mix average with peaks?
Marti D. Humphrey CAS aka dr.sound www.thedubstage.com IMDB http://www.imdb.com/name/nm0401937/ Like everything in life, there are no guarantees just opportunities. |
The whole point of people stating to calibrate your room, is that film mixers mix by ear!!
If the room is calibrated, there is almost no need to look at the meters, as the levels will all fall into place. Its not where youre dialog ends up on a meter, but how it translates to the ears in a 85dB calibrated position. Marti (Dr Sound), and Peter (PiratePost) have showed me my errors recently, as Ive been mixing by meter keeping my dialog around -20 but the relative loudness wasnt there, I remixed a show which now sounds louder (clearer), and my dialog now sits at -22. Its ALL relative, Im sorry to be redundant, but I saw the light, or maybe I heard it.
IMDB |
How to calibrate 96 i/o | EarHole | Pro Tools TDM Systems (Mac) | 3 | 06-06-2009 09:26 PM |
Calibrate 002 monitor outs to console ctrl room...? | beesee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-08-2008 06:26 AM |
How do you calibrate your front end w/ your 001? | jeronimo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-31-2005 04:31 PM |
calibrate i/o | DeadboysThing | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-24-2003 07:41 PM |
Anyone out there using 31 band EQ's and Pink noise to calibrate monitors to the room? | ckerian | General Discussion | 6 | 01-14-2002 08:22 PM |
