Old 07-27-2020, 09:47 PM
basslik's Avatar
basslik basslik is offline
Default Digi 002 rack
I just bought a used 002 rack, and would like to know two things.
I surrendered my PT9 license for the upgrade, but can always buy a used license so I can use the DIGI 002 rack if I have to use older versions of PT, which would be cool to pull up old sessions.
What's the last version of Pro Tools & drivers I can use with the DIGI 002 ?
I pretty much have every OS I need for for my too. thank you.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 07-27-2020, 10:23 PM
JFreak JFreak is online now
Default Re: Digi 002 rack
Driver downloads here
Old 07-28-2020, 03:59 AM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
I'm still using an 002R with PT 2018.3 (where I stopped updating) without any problems.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring.
Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n
Old 07-28-2020, 05:43 AM
You always need to try if it works for you or not. With that said Rack version is more likely to be usable longer as it only has the interface, without control surface. What I have heard there will be problems with control surface first.
Old 07-28-2020, 03:40 PM
basslik's Avatar
Thanks folks,
Wizzoboy I see you are on a PC correct ?, I'm on Mac.
I'm having trouble lion seeing the audiocore multi channels?
I'm researching and I believe someone out there is on Mac mt. Lion or Lion running PT10 or 12 ?.
I'll try the boot sequence I heard about.
Old 07-28-2020, 03:54 PM
CoreAudio
But what do you mean exactly?... The Avid supplied 002 driver you installed is likely to either install and work totally or not. It's not likely to only become a two channel device. What does the Mac's Audio MIDI Setup app show for the devices? (post a screenshot of that if it is easier).
What shows up in Pro Tools Setup>IO might be a two channel device even if everything else is working OK. But that's just confused IO settings. Make sure that the Playback Engine selected is really your 002 and then Default that IO. (delete all the paths, then click the Default button on each tab in Setup>IO).
If you 002 is not working at all then Pro Tools will likely default to using the Built-In output as the Playback Engine and that can show up with only two output paths. And it might be possible say they end up with names that make you think your 002 was actually working and only two channels. Always explicitly check the Playback Engine is what you think it is... so easy to trip up when that changes.
Old 07-28-2020, 05:14 PM
basslik's Avatar
Hi Darryl,
Running Lion PT10, iLok3 plugged in. 002 rack appears functioning as the manual indicated, sample rate light & mute light, as well as the 1394 firewire port on.
I've installed every version of drivers starting from 10.3.3 (9.0r3) worked my way up the the last version 11.1.5 since I seen someone on Youtube successfully run it on PT12.
Not letting me upload screenshot.
Shows audio core device 0in/0out
Pro Tools Aggregate 4in/2 out.
Every version I did uninstall the previous versions of drivers also.
Old 07-28-2020, 05:31 PM
basslik's Avatar
I think I uploaded correctly ?
Old 07-28-2020, 05:39 PM
OK so the device is showing up but with 0 in/0 out... that may mean the driver is not working at all or may just be upset. Is the 002 connected and powered On? Leave it powered on and reboot your Mac... now what does it show up as more than 0 in/0 out.
This all at least makes more sense than two channels.... you should not ever see than.
You are clicked on the aggregate device in Audio MIDI Setup... but you hopefully are not trying to use that... and are using the 002 directly. I suspect your Pro Tools is starting up with the Aggregate Device as the Playback Engine and you are simply seeing the two audio outputs in that that are in that aggregate.
Old 07-28-2020, 06:21 PM
basslik's Avatar
Yeah all I see is the aggregate. I also did the midi fix install.
Connecting Eleven Rack to Digi 002 Rack TMitchJobe Eleven Rack 12 02-02-2013 10:54 AM
Rack Mount Ears for Digi 003 Rack Flux06 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-28-2008 02:49 PM
digi rack 003 rack spaces keepeatingcars 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-06-2007 02:28 AM
Digi 002 Rack or Factory Rack? liquid32 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 07-08-2005 02:43 AM
Digi 002 Rack + Control 8 or Digi 002 Full System YogiBear 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-09-2004 09:38 AM
