Old 12-19-2003, 12:27 PM
(((k))) (((k))) is offline
Default How to use non quicktime video formats in PT?
Can this be done? I am trying to use a DVD, do I need to convert it to quicktime? I am totally lost here because I can't figure a way to change the DVD into anything quicktime. Any help appreciated I don't know anything about video.
Old 12-19-2003, 03:50 PM
antiphase antiphase is offline
Default Re: How to use non quicktime video formats in PT?
uh............u don't .........convert to quicktime then you're cool.
www.soundgeekproductions.com
Old 12-19-2003, 04:18 PM
Uh...........I have tried everything to convert my DVD to quicktime. It is the wizard of DVD and quicktime won't open it let alone convert it. Unless there is something I am missing?
Old 12-19-2003, 06:07 PM
ah...........well then you're trying to do something that might not be legal.
Old 12-19-2003, 10:57 PM
I meant the wizard of oz.
Old 12-20-2003, 07:48 AM
froyo froyo is offline
Hello. I assume you mean you want to spot audio to video from a DVD correct? You have to capture the video from the DVD first. You will need a video capture card and capturing software. iMovie can do the capturing and if your DVD player has Firewire then you don't need anything else. Otherwise you need to get a video capture card or device, like an Aurora, Canopus, Miro, etc. Once you capture the video into iMovie you can create your QuickTime movies there. Good luck.
froyo
Old 12-20-2003, 04:19 PM
just a hunch, but from the looks of his (((name))) he's not trying to use a capture device for the DVD lol.
Old 12-21-2003, 07:58 PM
I really can't figure out what you are implying. I assume you mean something about copying a DVD LOL. Well, I paid money for this DVD so if I want to convert it so that I can play around with this movie in PT in my own home or even make back up copies for myself I can. It's when you give them to other people that you're stealing.
Yes I want to spot a video and PT only allows Quicktime to be the player. I literally spent hours researching codecs and all that video stuff. I found a cool program that will decrypt .VOB files so you can run them without the disc. With the QT MPEG 2 component you can watch decrypted .VOB files. The catch is quicktime does not support AC3 sound so you have to convert the file again which is where I am confused so I have to learn more. I was able to get it to work though without sound. All I need to do is convert it to a codec quicktime can read and I can have sound and hopefully a largely compressed file. The .VOB is really like an MPEG2 so it is like 4 gigs. It is also in several files so I can't use it how I like in quicktime. If anyone has an idea of what codec to convert to that would help. I want it compressed a ton and to be quicktime compatible. Thanks
ƒ©?ߥ®†ø˜æ?œµ¬¬“˜?æ… øˆ¶§?ƒ©¥??¨?¥(((((((((((((kkkkkkk)))))))))))))))•§ ?ˆ¶§?¢•§¶?¡º?ªªªƒ?ß圬ø?˜*…´ß¥´ß¨?ƒ¥©¨?
that's for you antiphase
Old 12-22-2003, 12:07 AM
Hoepffner Hoepffner is offline
You have DVDxDV <www.dvdxdv.com> who do the job perfectly for NTSC (for PAL there is some problems with codec). It gives you a perfect QT movie with sound, usable in PT or DP. It work with NTSC DVD to NTSC DV or from PAL DVD to PAL DVCPro (there is the problem, you have to transcode it as to watch it in PT)
Old 12-22-2003, 01:30 AM
ok..........well you might be right if you have "authorization" to re-produce this DVD. Doesn't matter if you sell it or not......sorry,but the "reproduction" part is not exactally your freedom of choice.
Video question 2: Changing video formats in session johnnyv Pro Tools TDM Systems (Mac) 1 03-18-2010 09:56 AM
Video formats Fullsound Recording Pro Tools TDM Systems (Win) 4 10-07-2008 12:01 PM
Video Formats hughwes Pro Tools TDM Systems (Win) 1 08-18-2007 01:10 AM
Quicktime Formats? Dean Jones Post - Surround - Video 8 07-12-2006 10:44 AM
video formats??? Jorge442 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 01-03-2004 06:11 AM
