Old 01-26-2024, 07:37 AM
MackieD MackieD is offline
Default Looping like a hardware looper
I hope this is the correct place to pose this question. I would love to set up an 8 or even 12-bar loop. My idea would have 5 or 6 softsynths on separate instrument tracks. My hope is that there would be a way where Pro Tools acted more like a Boss looper where once the first loop was recorded on track one I could switch to track 2, as seamlessly as possible, hopefully without being forced to stop down and re-arm.
Hope that makes sense. Any help greatly appreciated!
Old 01-26-2024, 08:11 AM
K Roche's Avatar
K Roche K Roche is offline
Default Re: Looping like a hardware looper
Interesting question and yes being a guitar player with some looper experience makes total sense
I don't know for sure --But I don't think it is possible at least not without as you say either stopping to change the record arm status
OR
With the possible exception (but I have never tried it ) of having enough room at the end of loop to undo record arm on that just recorded track, and then record arm the next track all while having the click keep going
(With Midi in PT you can record arm on the fly ) But not sure that accomplishes much over just starting and stopping and using preroll and the click which is also only going to take a few seconds.
Either way unlike the looper you are not going to be able to come in right on the down beat without there being a silence gap in between the different takes
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 02-06-2024, 07:50 AM
DetroitT's Avatar
DetroitT DetroitT is offline
I have not tried this but what about “trackpunch” in loop record?
Old 02-06-2024, 12:14 PM
Actionmusic Actionmusic is offline
You might be able to do something with Melda Superlooper https://www.meldaproduction.com/MSuperLooper
Old 02-11-2024, 05:26 PM
skylar_battles skylar_battles is offline
MIDI loop recording will be wonky until playlists are fully supported, but you should be able to freely switch between INST recording tracks with command up and down. Loop record on will give you separate MIDI clips per recording pass which is what you’ll want for this workflow. The other option is loop playback, regular record mode, and midi merge on to overdub midi per loop pass. You can always punch in on midi. Effectively the only recording modes are loop record and regular record. Quick punch is effectively the same as regular record mode because you can’t drag our pre-roll for example for MIDI. The other newer record modes are only supported in Audio and redundant for how MIDI works in Pro Tools.
Pro Tools Ultimate 2024.3.1
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.4
New Boss RC-505 (Looper) PT 10 Master/Slave godam MIDI 0 05-11-2015 05:14 PM
Need help: RC-300 looper connection? strivingfirst Eleven Rack 10 08-16-2014 06:32 PM
No signal from Ditto Looper in the FX Loop of the Avid Eleven Rack dcasner64 Eleven Rack 8 02-18-2014 06:11 PM
Echoplex Digital Pro Looper with Foot Pedal and Manual jav Buy & Sell 0 09-23-2012 11:18 AM
Boss looper Marshall881 Eleven Rack 3 03-16-2012 08:30 PM
