US $299 Apogee BOOM (2 IN x 2 OUT USB-C) Onboard DSP FX - ECS Channel Strip
Apogee-BOOM[3].jpg https://apogeedigital.com/wp-content...pogee-BOOM.png https://apogeedigital.com/wp-content.../Boom-Rear.jpg ECS Channel Strip, tuned by Bob Clearmountain https://apogeedigital.com/products/boom Quoted from the link above: Get 50% off the Symphony ECS Channel Strip or any native plugin when you register BOOM BOOMs preamp can power the most demanding mics like the Shure SM7B with up to 62dB of clean, noiseless gain. BOOMs studio-grade headphone amp and DAC will power anything from in-ear monitors to high impedance headphones, thanks to its zero-ohm headphone output. The result? Your headphones benefit from more clarity, dynamics, and perfectly balanced frequency response. https://apogeedigital.com/products/boom#features FEATURES Best-in-class Apogee conversion and mic preamps Up to 24 bit / 192kHz recording 2x2 USB-C audio interface 1x Ό Instrument input 1x Combi mic/line/instrument input 2x Ό Balanced outputs 1/4 Headphone output Low profile design with aluminum body Bus powered On-board hardware DSP for low-latency recording with Apogee FX Symphony ECS Channel Strip - Hardware DSP FX (Native plugin sold separately) macOS, Windows 10 compatible IN THE BOX BOOM USB Type C / Type A cable COMPATIBILITY macOS: 10.15 and later iOS / iPad OS: 15 and later* PC: Windows 10 Anniversary update or later *All iPads with an USB-C port are compatible with BOOM. Devices with a Lightning port require the camera connection kit and a powered USB-A hub. SPECIAL OFFERS* Ableton Live Lite free Apogee Soft Limit plugin free Receive an Apogee web store coupon for 50% off any Apogee plugin or plugin bundle Exclusive 60 day plugin trial from Neural DSP *All offers require registration of new BOOM on Apogee website SPECIFICATIONS MIC PRE EIN: 128dB (un-weighted) @ 62dB, 150 Ohm input Max Input Level: +18dBu Input Impedance: 2.4KOhm HI-Z Max input level: 14dBu Input Impedance: 3.2kOhm (Pad on), 1MOhm (Pad off) A/D CONVERSION Max input level +4dBu: +18dBu Max input level (-10dBV ref): +6dBV Input impedance: 6.4KOhm Freq resp 20 Hz -20Khz: > +/-0.2dB (@44.1Khz) Rel. THD + N: -100dB Dyn. Range: 122dB (A-weighted) D/A CONVERSION Max output level (+4dBu ref): +15dBu Line output impedance: 100 Ohm Freq resp 20Hz -20 Khz: > +/- 0.05dB Rel. THD+N : -107dB Dyn Range: 117dB (A-weighted) HEADPHONE OUT Max output level headphones: 15dBu/24mW@ 30 ohms Headphone output impedance 0.5 Ohm Freq resp 20Hz -20 Khz: > +/- 0.05dB Rel. THD+N : -107dB Dyn Range: 117dB (A-weighted) PRODUCT SIZE Weight: 2lbs. / 0.95 kg Dimensions: 9.84 x 2.95 x 7.48 / 25cm x 7.5cm x 19cm https://youtu.be/WCHkgbzaBcA
Pro Tools Studio 2024.3 * Studio One Pro 6.6 * Harrison Mixbus 10 Pro * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 & Air 32 MINI * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock * 3 TB Samsung SSDs * 3 Screens: 15.6 Laptop & 24 BENQ LED GL2450-B & Samsung 27 CT550 curved Monitor Last edited by unkJE; 09-16-2022 at 07:45 PM. Reason: pics added |
Re: US $299 Apogee BOOM (2 IN x 2 OUT USB-C) Onboard DSP FX - ECS Channel Strip
Pretty Avid purple
... and purple knobs, too!
Pro Tools Studio 2024.3 * Studio One Pro 6.6 * Harrison Mixbus 10 Pro * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 & Air 32 MINI * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock * 3 TB Samsung SSDs * 3 Screens: 15.6 Laptop & 24 BENQ LED GL2450-B & Samsung 27 CT550 curved Monitor |
MH Channel Strip | Peter Baird | AAX Plug-ins | 1 | 09-02-2016 05:42 PM |
Channel Strip Bug | soundeditor76 | Pro Tools 10 | 7 | 08-02-2013 02:33 PM |
New URS Channel Strip Pro! | George Ware | Pro Tools TDM Systems (Win) | 4 | 08-03-2007 04:59 AM |
New URS Channel Strip Pro | George Ware | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-04-2007 09:40 AM |
Renaissance channel vs Channel Strip | frenchman | Tips & Tricks | 1 | 09-20-2003 05:18 AM |
