Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 02-23-2021, 11:50 PM
Fernando Fernández Fernando Fernández is offline
Default Protools doesn´t save IO Preferences and other settings.
I have a problem with protools, in this version, protools doesn't save my preferences, I/O setup, recent projects, peripherals and I have to set every days, could you help me please?
Old 02-24-2021, 12:39 AM
Top Jimmy's Avatar
Default Re: Protools doesn´t save IO Preferences and other settings.
It sounds like there might be a permissions issue. I would do a clean uninstall and then install Pro Tools again.
James Cadwallader
Old 02-24-2021, 01:16 AM
Thanks for request me.
Which is the most better mode to unistall protools?
Old 02-24-2021, 02:03 AM
Just run the installer there is no need to uninstall stuff. There is no uninstaller on Mac.
But before you do that have you tried just trashing preferences?
If this was happening to me I would look at the preferences files (the ones you would trash) and see what the create and modify dates are, what the owner/group and file permissions are and then trash then. And look at the owners/group permissions on the ~/Library/Application Support etc directories.
Old 02-24-2021, 02:14 AM
I reinstalled again and I have the same problem... I saw the folders and I cannot see nothing bad.
I change the theme to dark but doesn´t change when restart protools. This is the problem, I change the preferences and don´t change.
Old 02-24-2021, 05:22 AM
What OSX are you running? Are you running as admin?
Jack
QAPLA!
Old 02-24-2021, 05:30 AM
Yes, I´m running like Admin and the OSX is 10.15.7
Old 02-24-2021, 06:31 AM
JFreak's Avatar
JFreak JFreak is online now
Just one question. Are you always using same interface or swapping between built-in audio and interface? I have seen this behavior when you swap interfaces but if you keep using one and the same it should stay the same.
Also you can save your IO and reload, it makes it easier to swap between systems.
Janne
Old 02-24-2021, 07:36 AM
Thanks for the request, The problem began when I changed my mac, I use in my study on line.
when I changed the protools version, shows this problems.
Old 02-24-2021, 07:55 AM
_JJ_ _JJ_ is offline
Check System Preferences >> Security & Privacy >> General and see if there is a standing request to allow PT to install something. Unlock and allow if necessary.
Then while you're there look at the "Privacy" tab, scroll down to "Full Disk Access" and add ProTools there, or tick the box if it is already on the list but unticked.
Hope that works.
AVID: EuCon 2.71 doesn't save settings ilovemyssl Artist Series 7 06-21-2013 05:04 PM
Save Preferences chaosdemonz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-12-2012 11:22 AM
Save Preferences chaosdemonz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-11-2012 03:18 PM
Can't Save Preferences migel$ Pro Tools M-Powered (Win) 1 03-28-2009 05:06 PM
PT 7 save preferences. Allbaldo Pro Tools TDM Systems (Mac) 5 10-19-2008 02:46 PM
