Old 07-20-2018, 03:33 PM
jpmorgan jpmorgan is offline
Default playback engine won't reset
Yesterday, I tried to open a session I had recorded with an older version of ProTools, but doing that screwed everything up. My media players stopped working completely - no sound. So I opened ProTools while holding down the N key, (I'm using version 12.4 with Windows 10), and I reset the playback engine to my Yamaha Steinberg UR mkII, which I'm using as an interface/mixer. Then I restarted the computer.
This brought my media players back, and I have sound again, but ProTools still can't initialize my Steinberg. So, I can't play or edit a session, even though, as you see in the attachments, the Steinberg appears as the default playback engine.
If I click on the Setup to check to make sure, after that, ProTools won't close, and I have to shut the program down.
Can someone please advise me what to do to get things back to normal again?
Old 07-21-2018, 08:07 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: playback engine won't reset
Check in Control Panel>Sound that your Steinberg is NOT the default for Windows sounds/audio - make your onboard soundcard the default. This may or may not be the issue, but it is recommended.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 07-21-2018, 04:16 PM
But I want my Steinberg to be the default, not the on-board soundcard. Earlier when I had an MBox Mini as an interface, I tried doing what you recommend, and switching to the MBox when I wanted to record with Protools 10. This always caused problems for the same reason. I'd get the message that ProTools could not initialize the MBox.
Old 07-24-2018, 08:55 AM
Exactly why you need to do as weed recommended. If Windows is using the interface, it prevents Pro Tools from using the interface.
playback cuts out with plenty of CPU power left, have to change playback engine jmac146 Pro Tools 11 7 10-02-2016 11:34 AM
Possible Issue .. after BTD .. need to Reset Playback Engine .. john1192 Pro Tools 12 4 07-18-2016 08:19 AM
Playback Engine Issue (Won’t load session with chosen playback engine) MattyJones Pro Tools 11 0 11-02-2015 11:52 AM
Playback Engine>Current Engine issue Hunterkiss macOS 0 06-28-2013 01:14 PM
No m-audio interface in current engine (playback engine) SlicerSounds Windows 1 10-04-2012 12:27 AM
