Old 06-07-2001, 11:10 AM
SteveU SteveU is offline
Default Saving a song(audio, fade, ind.tracks) to CD?
Two questions, can I send my brother(who also has a digi 001) a CD of the complete session files(fade, audio, multi-tracks? Also, I have a friend who is running the Digi001 on PC, can we send each other saved versions like I asked about above and have them be "cross-platform compatible"?
Thanks ahead of time!
Steve
Old 06-08-2001, 07:47 AM
DigiTechSupt's Avatar
Default Re: Saving a song(audio, fade, ind.tracks) to CD?
Assuming you are running PT LE 5.1:
-If your brother is running PT LE 5.0.1 or earlier, you will need to choose File>Save Session Copy In and save the session(s) files in PT 5 format.
For cross platform compatibility, you and your PC friend must be running PT LE 5.1:
-Open the desired session(s) in Pro Tools 5.1 Mac
-Choose File>Save Session Copy In”
-Choose either AIFF or WAV for the Audio File Type
-Enable the “Enforce Mac/PC Compatibility” option
-If you are burning CD’s of your data to bring over to the PC, make sure you use the ISO9660 format.
-If you are using SCSI, you can copy all of your audio and session data (once converted) to the drive and mount it on the PC using a program from Datviz called MacOpener http://www.dataviz.com It allows you to read, write, and format Mac HFS drives, CD's, Floppies etc.
Avid Audio Tech Support
Support FAQ
Not saving fade files in backup Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-14-2010 08:05 AM
Saving project to 6.9 format with Elastic Audio tracks rainsong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-25-2008 12:16 AM
Saving Sessions and missing fade files Kevin01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-30-2006 10:23 AM
Best Way to Fade a Song slangification Pro Tools TDM Systems (Mac) 28 08-29-2005 02:02 PM
How do I fade volume at end of song?? jasonguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-26-2004 05:05 AM
