Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 03-29-2018, 10:15 AM
Larry O Larry O is offline
Default Pro Tools 10 + Focusrite Scarlett 2i2 buffer issue
Whatever buffer setting I use on my ASIO Control Panel on my desktop gets changed to 32 whenever I launch Pro Tools. If I make changes once I've opened the session, Pro Tools makes me quit and re-launch, only to discover the buffer is back at 32.
I have updated to the most current ASIO driver Focusrite has available with no luck. When I put my Mbox Mini back on line I have no issues. When I launch other audio apps (Sound Forge, Audacity) the buffer settings stay put, so this seems to be a Pro Tools thing. I have gone into I/O settings and clicked default through all the tabs, no change. I have navigated through Import Settings>Avid>Pro Tools>DAE>IO Settings and get the options from the attached screen shot, but honestly have made no changes because at this point I feel myself tumbling down the bunnyhole.
Any suggestions? I'm a casual user with a home studio.
Win 7/PT 10.3.9
Appreciate any assistance.
Larry
Old 03-29-2018, 01:31 PM
Default Re: Pro Tools 10 + Focusrite Scarlett 2i2 buffer issue
Ok, I believe I found the culprit. Under Playback Engine settings I had checked the box "Ignore errors during playback". Unlike the Mbox, this dialog forces the Scarlett to default to buffer size 32. Unchecking this box now keeps the selected buffer size. Go figure.
Old 01-24-2023, 01:45 AM
bugnut bugnut is offline
Thanks, Larry. You probably saved me hours!
http://www.bugnutrecords.com
Interfacing Issue with Focusrite Scarlett 18i8 UberAubergine Pro Tools 11 2 06-04-2019 08:46 PM
Latency, Buffer size - switching from Eleven Rack to Focusrite Scarlett rpossum Pro Tools 12 5 08-27-2017 08:16 PM
Pro Tools using Focusrite Scarlett 2i2-working!! baxteradio Pro Tools 12 1 09-08-2015 11:55 AM
Pro Tools 11 with Focusrite Scarlett 18i20? hermonmusic Third Party Interfaces 24 06-27-2015 08:53 AM
PT11.0.2 full ed. + Focusrite Scarlett 2i4 issue Roland Shaak Windows 3 08-20-2014 10:57 AM
