#21
Re: Anybody using Korg Kronos with midi actually working?
I didn't ask which connection style you tried because I know you tried USB MIDI and 5 pin MIDI. What I asked was does the Kronos make you make a selection on whether to use USB MIDI or 5 pin MIDI? A lot of synths that can use both make you select one or the other; you usually can't run both at the same time. You might even have to reboot the Kronos between changes.
#22
Yes. I tried to set all of that, but the implementation of AMS in Yosemite is awful. MIDI Test is awkward (can't even tell if it works) and the same thing for Rescan Devices. What happened? Did I come to Mac and PT just in time for both to suck?
God - you give up 3D shading in Mavericks for minimalism in Yosemite, and you can't tell if it works. I think I liked OSX Mavericks better (and I never owned it - since I only started using MAC in Feb2015:)
MP 6,1: Quad:64GB,256GB Flash,2-1TB SSD in TB Dock,Mac OS 10.12.2/3-27"&1-34" Mons/Artist Ctrl,Mix(x2),Trnsprt, Eu 3.5/Apollo Quad TB2/M905 Dig/LSR4326P & BX8A Mons/PT12.7/LPX10.2.4/S1v3/Advance49, S88 Komplete Kontrol 11 Ultimate/Radial 6pk : 1073LB, MonoGama, 512C, VHD Mic Pre,611DYN,611EQ/Variax 89F, PRS C22, /FAS AxeFX II XL+/DM10Kit/Win10 on i-7 Haswell PC with 16GB RAM/828mk3 FW/CW2016Platinum/Tobias&Tune Basses, Mesa M-Pulse 600, GK 1001RB-II Bass Gear/Neumann, CAD, AKG, Telefunken |
#23
I have the same computer, interface, I used to have an Artist Mix and Transport, the only thing different is I have HD, a Yamaha MOX8 going through an ancient AKAI Midi patch bay then to a MIO, and I'm on 10.10.2. There is one other thing we have not discounted. Your Win box might have USB 2.0, the trashcan has USB 3.0. I know it's supposed to be backwards compatible, but maybe there is something going on there...I have heard there is weirdness with an iLok and usb 3.0 ports with certain configs. Get Snoize and stop poking around in the dark.
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2. |
#24
#25
I have heard about the USB3 issue. I have tried direct USB3 on the can, and I have a Belkin powered USB2.0 hub. Neither one will work. My Win machine has 2 and 3 and my Kronos works on both. I am running 10.10.3. Wasn't the USB3 issue was supposed to be cured?
#26
I just downloaded Snoize. I see signal when I play the keyboard. Garageband has signal, too. This has got to be something setup wrong in PT12. I am flat out of ideas.
#27
Okay, so I don't know exactly what happened, but I can now play MID as long as I have the output on my Kronos set to Ch 10. Weird. My Xpand2 instrument 1 is on midi channel 1. Why is this?
I am not gonna complain, at least I can record now!I'll try to figure it out later. Thanks to everybody that tried to help me out here. Michael
#28
#29
#30
Pro Tools 10 Set up – mixture of Virtual, Korg Kronos, Vocal and Eleven Rack | ionactive | Pro Tools 10 | 7 | 02-18-2016 08:39 AM |
Pro Tools 11.3.0 - Korg Kronos - Midi Interface | Arkitorture | Pro Tools 11 | 2 | 02-26-2015 05:28 AM |
Working with Pro Tools 10, Korg and Mbox Pro | ionactive | Pro Tools 10 | 3 | 03-22-2013 11:17 PM |
Patches of a Korg Kronos in Protools 9: how to do? | Coyote13 | macOS | 0 | 09-01-2012 08:00 AM |
KORG microKONTROL working with ProTools? | LaForestPoetry18 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-05-2006 07:49 AM |
