  #61
Old 03-30-2015, 05:17 AM
Default Re: PT 11 and 12 installed on same Mac?
Originally Posted by DetroitT View Post
"27" mid 2011 iMac, 3.4 GHz quad core i7, 32 gig ram, OSX 10.8.5 & OSX 10.9.5 & OSX 10.10.1"
Hi Jack, I see you have 3 Operating system versions.
3 places (partitions) to have 3 versions of Pro Tools.
I agree access to the variations of most software should be available.
Especially during transitional times.
However. Backups and clones and not the primary-boot drive should be the proper testing place of anything new.
Title of thread:PT 11 and 12 installed on same Mac?
My view is Yes, the same mac, no to the same boot drive. Lastly your Hardware-Mac should determine the optimal-Operation System.
(10 and 11 of OS 10.8.5 seems a solid combination)
OS 10.10.x and PT's V11 only or V12 only.
(HD or Regular)
Avid has made sure we are all a bit edgy in rumor and knowledge.
Lets stay constructive.
(.....Back to my mix......)
I have the three partitions so I could try different OSX verions, not so I could run different PT versions. Machine originally came with ML and I wanted to try Mavericks because the Apogee Ensemble I want to get is Mavericks minimum. I have Yosemite to see what all the fuss is about and I have to say Yosemite is an out and out dog instability-wise when running PT. The optimal combo of operating system/hardware is not really driven solely by that but also what works with the software one wants to use. Yosemite by itself is stable as all get out but when using PT it's like the line from Forrest Gump: 'Life is like a box of chocolates; you never know what you're going to get' Substitute PT for the word 'life' and that's been my experience with Yosemite. ML and Mavericks have been rock solid no matter what I throw them.
I'm actually thinking of dumping the Yosemite portion as everything else I use or am going to use in the future (Digital Performer), does not require it.
Jack
QAPLA!
  #62
Old 03-30-2015, 06:24 AM
thewiz's Avatar
thewiz thewiz is offline
Lol.. Goodby then...No need for you to hang around here no more then.
  #63
Old 03-30-2015, 07:18 AM
Wasn't talking to you but whatever. Whether I want to hang around the PT12 forum or not is up to me to decide - not you or anyone else. You don't like me - fine - block me.
Jack
QAPLA!
  #64
Old 05-09-2015, 05:26 PM
nigelpry's Avatar
nigelpry nigelpry is offline
Ok, so I thought it might be worth refreshing the conversation …..
Did anyone get any further with co-installing 11 and 12? If so, is it ok? I remember reading in another thread about someone renaming the PT11 app so it doesn't get overwritten, but it then others queried whether the two versions share prefs files etc. Is there any definitive info on this that someone can point me to?
Also, I do have a legitimate reason for wanting them co-installed. It is something that will only affect a few people I guess, but it is nevertheless, IMO, legitimate usage. I know the backstop is to have them on separate partitions, but I shouldn't need to reboot to another partition every time I want to switch PT software versions.
And yes … Logic Pro 9 and X happily live together, as do Cubase 7.5 and 8, as do Wavelab 8 and 8.5 etc etc.
Anyway my reason for wanting both on one partition, permanently, once I've finished testing 12 and am happy to put it on my main partition is this ….
I have PT11HD, which I am not upgrading, I will leave it at version 11 (currently 11.3.1, but there may be more updates in the future). I'm not signing up to a HD support plan, I've decided enough is enough so far as handing money over to Avid is concerned.
I also have two student licences with free upgrades to PT12, which I won't be upgrading past the end of their four years of free upgrades period (one in 2016 and the other in 2017). I intend to put one of those licences onto my main iLok, which will then have a PT10+11 HD licence bundle, and a PT10+11+12 licence bundle.
And so I can see that I may well use both 11 and 12 on a regular basis as a standard (for me) workflow). If the stories about stability improvements and better VI performance prove to be true for me, then I will want to use PT12 for tracking and VI use. I'd then want to open the project in 11HD, to take advantage of multi-stem bouncing and for mixing (VCAs, automation modes, disc cache, extended metering, etc. etc.)
Comments please, from anyone with experience of co-installing 11 and 12.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10
iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6
Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors.
Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3.
Various apps, soft synths, FX plugins.
Plenty of hardware synths, rack gear, microphones etc.
And then there's the studio ;-)
  #65
Old 05-09-2015, 11:23 PM
ha2dorff ha2dorff is offline
I renamed version 11 to "Pro Tools 11" and installed version 12.
Works without any problems.
This way to do this was also confirmed by Avid support.
Another reason to update to version 12: The support respond from Avid is instant, and I use it from what it's worth
How to know which CS is installed ? ElMajdal Pro Tools TDM Systems (Win) 6 12-13-2009 12:49 PM
002 is not installed or is being used?? KingStudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 04-07-2009 11:55 AM
Just installed 7.3--HELP jwd65 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-20-2007 05:00 PM
HELP! I just installed 5.1 and... naman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-24-2001 03:35 AM
just installed 5.1 ? Karrot24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-04-2001 08:43 PM
