  #21
Old 03-25-2015, 02:29 PM
lexaudio lexaudio is offline
Default Re: PT 11 and 12 installed on same Mac?
Originally Posted by ha2dorff View Post
I guess the question has been raised, but anyway:
Is it possible to have both 11 and 12 installed on the same Mac?
Don't waste your time with PT12. I brings nothing. Russ from Pro Tools expert called this release garbage and uninstalled PT12 within an hour of installing it and went back to 11
Installing PT12 will uninstall 11. Stick with PT11
Ultimate 2018.7
MacPro 12 Core 3.46 - 10.13.6
128 Gigs RAM
EFI flashed 580 GPU
3 card PCI-e expansion chassis.
Avid Artist Control
Apollo 8 Quad, Satellite Quad, Octo Card
Cranesong Avocet Monitor System.
WireWorld ProAudio Cables
  #22
Old 03-25-2015, 03:29 PM
Becharax's Avatar
Becharax Becharax is offline
Well PT12 seems snappier for me ... at least for me since I had a lot of issues with 11 !
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
  #23
Old 03-25-2015, 11:55 PM
BrianJArmstrong BrianJArmstrong is offline
sounds like Russ is being quite dramatic. Screaming that it should just be called "11.4" but treating it like its toxic. If its just a minor update missing features, why would you uninstall it? If its buggier, slower, and more detrimental to your work, ok... go for it. But jeez... what a drama queen.
MacBook Pro: Retina, 15", Mid 2014
Processor: 2.5 GHz Intel Core i7
Memory: 16GB 1600 MHz DDR3
OS: 10.12.5
PT: 12.8 HD - no interface. headphones and ilok.
  #24
Old 03-26-2015, 09:34 AM
No drama queen but someone who realized Avid should not have charge $199 for this. And it is toxic when it deletes your PT11 install without any warning. Installing Pt11 didn't wipe out existing PT10 installs so why should PT12 wipe out PT11 install? I know the two programs have the same name but Avid should have in big bold letters:
INSTALLING PT12 WILL WIPE OUT EXISTING PT11 INSTALLS
Jack
QAPLA!
  #25
Old 03-26-2015, 05:36 PM
albertocarlassare albertocarlassare is offline
Pt10 / Pt11 dual installation were thought to assure plugins compatibility. Pt11 is the first 64bits pt system and plugins since this version are aax64bits.
So, for purchasers with rtas plugins Avid let the possibility to install both versions of Pro Tools, making possible gradual plugins migration.
There's no reason to have both Pro Tools 11 and 12 in the same system because both versiones open same session files, use same plugins and so on.
  #26
Old 03-27-2015, 05:51 AM
You are mistaken; if one has a working system with PT11 why should that be jeopardized by installing PT12? There's no guarantee PT12 will work on a particular system so having something that is known to work is a must. Besides why would Avid allow one to have license assets for PT11 and PT12? It's like those of us that have multiple boot systems - so you can try new things without screwing up the existing system.
Jack
QAPLA!
  #27
Old 03-27-2015, 06:43 AM
Hi music man, I think we are speaking about two different things. I'm actually doing what you say. Pt11 on yosemite main system and trying pt12 in the second drives with mavericks. I'm intended to keep working pt11 on main system until I'm sure pt12 will get me good performance.
What I wanted to say is that there is no reason to need pt11 installed if pt12 is working in your system, because they arr basically the same; my tryarounds with pt12 make me believe pt12 isn't anymore a 11.4 sold as a new version.
They change startup dialog, some features into I/O but the engine is pratically the same. If you haver pt12 working I don't find any reason to run pt11 in the same machine. If you have dualboot and you want to keep 12 in one and 11 in the other, I find it great! You can as Avid leave in our iLok a bundle license 10/11/12.
Personally It think that doing that is like having 11.2 and 11.3 in the same system...why?
Dual installing 10/11 or 10/12 gives you the possibility to have both 32bit/64bit audio engine
  #28
Old 03-27-2015, 06:45 AM
JFreak's Avatar
JFreak JFreak is online now
Default PT 11 and 12 installed on same Mac?
Yes but remember that dual install specifically requires Mountain Lion
Janne
  #29
Old 03-27-2015, 06:53 AM
I'm talking about having both available in the same boot partition. Yosemite is not stable enough for me to use it in production or anything else. So your method would not work. You're also missing the thing of stability of PT12 itself and until that happens one needs to have access to both on the same machine and boot partition.
Jack
QAPLA!
  #30
Old 03-27-2015, 06:56 AM
You're talking about dual PT10/12 installs? What about those of us who have PT10 running no problem on Mavericks? I know it's not supported because of the uninstaller for PT10 not working in Mavericks but that's a minor issue at best as there's a manual way to uninstall PT10.
Jack
QAPLA!
How to know which CS is installed ? ElMajdal Pro Tools TDM Systems (Win) 6 12-13-2009 12:49 PM
002 is not installed or is being used?? KingStudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 04-07-2009 11:55 AM
Just installed 7.3--HELP jwd65 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-20-2007 05:00 PM
HELP! I just installed 5.1 and... naman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-24-2001 03:35 AM
just installed 5.1 ? Karrot24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-04-2001 08:43 PM
