Old 03-18-2014, 01:40 PM
BCnSTL's Avatar
BCnSTL BCnSTL is offline
Default PT11.n - no option to change sampling rate in "save as" dialog
I'm fairly new to PT and I have several sessions going well and discovered that the sampling rate is set to 48k. After searching the forum I see suggestions to do a "save as" and change the sampling rate there. I have no options to change or set anything other than the session file name in the "save as" dialog.
I'm running 11.1.2 on Windows 8.1 - thanks for any help!
Old 03-18-2014, 02:46 PM
mesaone mesaone is offline
Default Re: PT11.n - no option to change sampling rate in "save as" dialog
Use "Save Copy In". Make sure to tick the box next to Audio Files, under "Items to Copy".
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 03-18-2014, 04:14 PM
The Weed's Avatar
The Weed The Weed is offline
Or just change the sample rate when/if you bounce out.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 03-18-2014, 04:23 PM
Craig F Craig F is offline
"Save as" is for version naming
"Save Copy In" is for conversion and consolidation
Thank you,
Craig
"cannot save "XXXXXX" because while translating I/O settings" tdawgg Pro Tools 10 14 10-26-2013 02:27 PM
"Save in" dialog reduced??? Codo macOS 1 12-18-2011 01:37 PM
how to change "Defaults" in MP3 Option? chimpstudio Pro Tools TDM Systems (Mac) 2 10-21-2008 06:01 AM
"Bouncing" . . . . Can I CHANGE The "Default Setting"?? The Zone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-17-2002 02:59 PM
"Newbie" needs help on "save" and "drives" Thomas C. Gass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-30-2001 11:43 PM
