Old 08-07-2011, 04:01 PM
tyler23 tyler23 is offline
Default Meter Levels Don't Change
I recently made the switch to Pro Tools from Cubase and am needing some help with a small issue.
When I adjust a fader in the mixer, the meter doesn't change. For example, if I pull a fader all the way down on a channel, I can still see the meter bouncing away. Or if I crank a fader all the way up, the meter for that channel doesn't shoot up. Or if I mute a channel, the meter doesn't stop.
The reason I ask is because the meters in Cubase do change with fader adjustments.
I'm sure there is a simple solution. I appreciate your help.
Old 08-07-2011, 04:03 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Meter Levels Don't Change
options > pre-fader metering
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 08-07-2011, 04:15 PM
Thanks. Exactly what I needed. I knew it would be something like a pre/post fader option. I was looking in the preferences menu and elsewhere. Overlooked it in the options menu.
Thanks again.
[IMG] code is Off
meter bar won't change tocor123 Pro Tools TDM Systems (Mac) 3 04-07-2010 09:46 PM
My meter levels Greg555 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-21-2009 01:00 PM
VU meter & Audio Broadcast Levels for Dummies rabinrocks Post - Surround - Video 4 09-29-2008 12:30 PM
differing meter levels in m/bus and ext. desk??? req06 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-14-2006 04:08 PM
Meter Levels Won't Display During Playback digijohn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-22-2004 01:12 PM
