Desperate for help!
Hello,
I have just recently received my second MBox Pro. I sent the first back as I believed I had a hardware problem, however my new Mbox is just the same. When I switch on the Mbox Pro without it being connected to my MacBook Pro all the LEDs work fine, yet as soon as I boot up or launch Pro Tools, I lose the speaker switch LED, mono led and multi led. The phantom power and dim/mute leds work fine. I can record as normal, however there is obviously a problem somewhere. I am running Pro Tools 9 on a 13 inch MacBook Pro with 4Gb ram. As my laptop only has a firewire 800 port I have had to use the adaptor supplied with my bundle. I am desperate to get this sorted out as this is my second MBox Pro within two weeks and I'm still at square one. Please, if ANYONE knows how to help or any suggestions can you let me know? Do I need to purchase an AVID support code etc. Thank you for your time and consideration. Jamie |
Re: Desperate for help!
Not really sure what the problem is... Just the LEDs go out? Do the actual functions still work, or just the LED lights that stop workiing?
Are you turning on the MBox while the computer is on, or before? VERY IMPORTANT! Don't power your computer until the MBox is powered!
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
What OS version? What exact PT version? Have you loaded the hardware drivers and selected them?
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Wow! Thats a few questions...thanks very much! The swtiches actually don't work. The phantom power does and its led works as does the dim/mute, however the speaker and mono switches don't work. They do when the mbox is not connected to the computer though. The OS version is Snow Leopard 10.6.7 Pro Tools 9.0.3 I loaded the drivers that came with my pro tools bundle and up-dates from the AVID website. I just tried again, I powered the MBox and all LEDs worked fine. I then powered my MacBook Pro and when the log in screen appeared the blue power light on the Mbox began flashing. Once the computer had booted the power light stopped flashing and I lost power to the speaker, mono and multi buttons and functions as well. In pro tools I can select the Mbox in the playback engine and hardware menus. I hope this is clear, I apologise for any confusion and thanks again for your help, it is most appreciated. Jamie |
I would try reinstalling the drivers, then reinstalling Pro Tools.
Thanks Dism,
I have already tried that. This is the second Mbox Pro.. as I saidm the first was sent back because I though it was faulty however my new one is the same. I installed pro tools first then the drivers as per AVIDs website. Cheers, Jamie |
Just pitching in here, cause I don't have a mbox 2. But could it be the port of your laptop that is having problems?
Yes, perhaps you should try using Mbox with another computer so you can definitely eliminate one or the other as the cause of your problem.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Thanks,
I have a friend who has the exact same laptop so I will his to see if that could be an issue. Jamie |
Desperate | luoneill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 12-05-2010 10:46 AM |
desperate for help | shaela | Post - Surround - Video | 1 | 04-12-2007 09:53 PM |
NEED DESPERATE HELP PLEASE!!! | thumbolt68 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-14-2006 09:18 PM |
Desperate Need of Help | Sharritan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-21-2005 08:11 AM |
I am now desperate! Please DUC - come through for me!!! | winter20 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 11-30-2002 06:52 PM |
