Sending Inserts To AUX's
I was just wondering how you would go about sending an insert plugin to an Aux channel. I am using a reverb and want to be able to solo the wet signal on it's own in an AUX track so i can do some further tweeking. Any advice on how to go about this would be much appreciated.
Re: Sending Inserts To AUX's
The only way I know of is to put the reverb on an Aux and have your send pre-fader. This way, anything that's pre-fader and going to that reverb will be soloed when you solo that Aux.
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
this may work i'll give it a try
Right. This is one of the reasons there are pre-fader sends. The old "dry signal fades out while the reverb stays" thing. Or for reverb only tracks too.
Another good application is building alternate mixes for monitors, or headphones, or anytime you want to route the audio, processed by the channel plug ins, but not following the fader. |
aaaah i get you, i will try this
Tried making the aux effect returns "solo safe" so you can solo tracks with effects in place?
VCA's and Aux's | Raoul23 | Tips & Tricks | 8 | 02-17-2014 12:30 PM |
Possible to make an FX send/return without aux's? | kmoe | General Discussion | 0 | 05-16-2004 12:24 PM |
Ok...still not convinced about Aux's for Groups | mesh | Pro Tools TDM Systems (Mac) | 11 | 08-26-2002 03:38 PM |
Why can't the aux's sum like a master fader? | mesh | Pro Tools TDM Systems (Mac) | 21 | 08-05-2002 09:29 PM |
Submixing with Aux's ....quality loss? | mesh | Pro Tools TDM Systems (Mac) | 0 | 06-23-2002 07:21 AM |
