#21
Re: DAE error 9031 in PT9, fixed?
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1 Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX. |
#22
I've still got serious doubts about structure, but it's not an option for me to even try removing it from the plugin folder. It's running the drum triggers for about 75% of our sessions, plus various other things. With such an intermittent error I can't even test potential solutions unless I can continue to run normal sessions.
I'm especially annoyed because I WAS talking to AVID via the customer success thing, and the last communication I had in January was this: Quote:
#23
What a frustrating bug. I also get these semi-frequently. It is almost like I can sense it coming right before it happens. However, I don't think I have had one since updating to 8.1.1 But I think I have probably just been lucky.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
#24
Make that 3 today. And the last time PT wouldn't relaunch after until I rebooted. I think I may cry a little.
#25
I guess this isn't a problem anymore. Did anyone figure out the solution?
When it happens to me I go in and do a lot of things like limit to 4 cpu's/more buffer/yada ...and suddenly it works, no idea what was the cause ... |
#26
No, I caved and went to PT9. Had no errors since, but there never was a solution under PT8. Avid were completely unable to reproduce the issue in their testing department so couldn't help very much. I went through every hardware and software test imaginable trying to find a cause, but no joy. It was always very intermittent for me too, but I never changed playback engine settings so I certainly don't think that has anything to do with it. I'm afraid your choices are upgrade or live with it. Sorry!
#27
Also this error happens when your external drives are FW800 and bussed down to FW400 and vice versa..... In theory this should not happen but it is an error that I can recreate... I have not alerted Avid with a thread however... Too busy...
#28
But then on a few recent sessions, I had some drum samples just as WAV files that I wanted to use, and for convenience sake (not ReWiring a separate application) I decided to try using Structure Free for triggering samples. On these sessions (and these alone), I have been getting several of these 9031 errors a day. Yes, the kind where I have to quit and relaunch Pro Tools for it to clear. I've tried opening Hardware Settings, and switching buffer sizes around to try to force the DAE buffers to reset. No luck there - a relaunch was still needed. And while in Hardware Settings, I turned the Disk Streaming Buffer, or whatever that's called, up to max - didn't help. So, Structure Free is the culprit, at least in my case. So much for convenience... Leigh PT 8.0.5 (M-Powered) Profire 2626 Mac OS 10.5 Last edited by Leigh Marble; 09-29-2011 at 10:21 AM. Reason: added system information |
#29
Sorry to hear you guys get this problem too, but glad to hear I'm not alone.... it's a real pain - appears often during playback (mixing) but rarely when recording (even when looping). I've got no firewire drives and have never used Structure and this problem is much worse in PT9 than it was in PT8.n.
Not happy Jan :-(. |
#30
The -9019 / -9031 combo is killing me today. I've gotten that thrown up at me 9 times in the last 6 hours. Really great for workflow to have to watch your computer lock up for a minute and then need to relaunch PT on top of that.
Once thing I didn't mention, though maybe someone else did here - I always get the 9019/9031 combo at least twice in a row. In between, there's a long pause, while PT's windows have greyed-out title bars, and the application is inaccessible. So, f' this, I'll print the Structure Free tracks to disk and disable those plug-ins. See if that makes the errors stop. Leigh |
DAE error 9060 9031 | ellebye | Tips & Tricks | 0 | 01-03-2014 04:01 AM |
Error -9019 and -9031 | henrikas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-05-2011 09:34 AM |
DAE Error -9019 & -9031 since PT 8.0.3 | reichman | Post - Surround - Video | 91 | 01-24-2011 12:00 PM |
Getting DAE 9031 error on Snow | crizdee | Pro Tools TDM Systems (Mac) | 0 | 07-22-2010 09:30 AM |
DAE error -9031 was encountered | fretfingers | Pro Tools TDM Systems (Mac) | 11 | 04-25-2010 09:52 PM |
