Old 09-21-2010, 11:07 AM
soundonthemoon soundonthemoon is offline
Default Got some trouble with clock "mismatch of sync source"
Hi there,
I got some troubles with my pt HD,
just bought a new ad 16 x and now i got this message "Too many slots on the TDM2 bus - could indicate an unplugged audio interface or a mismatch of sync source and session sample rate. (-6075)"
So there is my setup:
I got a PT HD 3 with 3 da16x (each one are connected to a pci card) my ad16x is connected to the 2nd DA16X.
I also got a big ben who send clock to all my converters. But the big ben is synced from another device (the weiss afi1).
Off course all the apogees are set on external wordclock even the big ben and the sync i/o too.
In my session setup window the wordclock source is set to wordclock...
I really don't know what to do cause when the error window appears i just click on ok and i can going back to my work without troubles...
Thank you..
Quentin
v9.0.3 never opens with proper digi "clock source" glankrudolph Pro Tools 9 3 04-12-2013 09:45 AM
Audio clock problems.."Check clock source and sample rate.." Please help! beasleymusic Pro Tools M-Powered (Win) 1 08-03-2011 10:54 PM
Error: "Problem detected with audio clock. Check that your clock source and sample... mongo_man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 05-01-2010 06:08 AM
"Problem detected with audio clock. Check that your clock source and sample......... ASD15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 03-26-2010 03:40 PM
Must change "Sync Mode" each time I change recording source? el biciclista 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-23-2001 04:48 PM
