Old 08-26-2009, 10:57 AM
Patill Patill is offline
Default Bit-Rate and Sampling Frequency change of a session???
Hey,
I would like to change the bit-rate from 16 bit to 24 bit and the sampling rate from 44.1 kHz to 48 kHz, since this is recommended when you record a CD. I thought I go woth the CD defaults, but I´m propably wrong .
I can re-record the audio material, so what´s left in the sessions is just instrument tracks with some RATS instruments (Battery and Xpand2).
Is it possible to change it easily? How do I do that?
Old 08-26-2009, 11:09 AM
JonesH JonesH is offline
Default Re: Bit-Rate and Sampling Frequency change of a session???
I'd create a new session @ 24bit/44.1 kHz and then use Import session data. Don't runt 48k sampling rate when the end product is going to CD, you just need to make sample rate conversions from 48k to 44.1k.
I just wanna do engineering...
(as opposed to make music :/ )
Old 08-26-2009, 11:13 AM
1ace1 1ace1 is offline
You can also go to the 'Save Copy As' function and change the settings of the session there (the new settings will be in the saved copy).
A
I Love Audio!!!
Old 08-26-2009, 11:21 AM
ah ok.
I´ll try that, but somebody´s gotta help me out, I once tried saving a copy and some stuff was gone after .
I´d like to have it as a copy so I can delete the original without loosing stuff.
Now a very important question:
Is there any quality loss when I do that??? I mean saving a copy with 24 bit?
Old 08-26-2009, 11:27 AM
the bits shouldn't make a big difference (it just will be representative of a 16 bit recording) but upsampling just adds samples that are already there to fill in the gaps so it is destructive to the raw data. resampling would be the best way to go but again would be somewhat destructive. rerecording would be ideal!
A
I Love Audio!!!
Old 08-26-2009, 01:37 PM
allstaar's Avatar
allstaar allstaar is offline
If you were saving a session copy at the same bit depth and sample rate, you'd need to make sure it copies all audio files as it is an option for it to reference the audio files in the current session. To avoid this, check "copy all audio files" in the save session copy window.
If you're creating a session copy in either a different bit depth or sample rate, Protools has to create new files so always copies all audio files. In your current scenario, this is what would happen.
After you've done a session copy, it may be worth moving the old session to the trash temporarily and then opening the new one to make sure it has all the audio files it needs. Protools cannot reference audio files in the trash, so this is a way to check, if you're at all worried.
Old 08-26-2009, 02:47 PM
albee1952 albee1952 is online now
Excellent advice above. I also agree that recording at 44.1 saves a sample rate conversion(although there are some that feel the conversion can smooth off rough edges). I usually work at 44.1K and always(unless someone else started a project) record at 24 bit for the increased headroom. That allows you to be more relaxed with your record levels(good for avoiding clipping with that singer that has no mic technique). Just remember that a 24 bit file will need to be dithered to 16 bits for burning audio CD's.
Old 08-27-2009, 06:24 AM
Thank you everybody, have big work to do now
A
Yes, I´ll rerecord the audio files, that´s no problem. But what about the instrument tracks? They shouldn´t have any quality loss at all right? Or do I have to change something there, too?
Old 08-27-2009, 07:11 AM
They SHOULD be fine as far as I'm aware.
A
I Love Audio!!!
PT11.n - no option to change sampling rate in "save as" dialog BCnSTL Pro Tools 11 3 03-18-2014 04:23 PM
Session sampling rate messup, what are my chances? digidesigner Pro Tools TDM Systems (Mac) 2 11-02-2011 10:39 PM
How to Change A Session's Sampling Rate homegirl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-17-2007 01:29 AM
Can I change the sample rate of my session? Help! Allbaldo Pro Tools TDM Systems (Mac) 9 05-09-2006 01:05 PM
Sample rate change during session? JonMitchell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-02-2005 10:47 AM
