volume trim in PT LE
Hi!
I have digi003 PT le 7.3.4 at home and I just came from a pro studio where I noticed that the engineer was using Volume trim. I have now been searching for this feature in my home system but can´t find it! where is it? or is it only in HD systems? or 7.4 +upwards? many thanks. |
Re: volume trim in PT LE
It's an HD only feature.
I use ProTools M-Powered 7.4 and I have a mono TRIM plugin. Just click on an empty plugin bank and chose mono, then other. Thats where my TRIM plugin is on my machine. If you want the Audio Suite version then click the AS drop down, close other and then use the GAIN plugin.
Hope this is what your talking about!! Nick |
hmm, that´s bad.
do you know if it will available in PT LE version 8? |
you talking about VCA faders or Trim automation option?
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
Describe what happens as there may be a simple way in LE to accomplish the same end.
Trim automation option.
with the trim tool, pull down your volume automation to the right of the last breakpoint, this will effectively do the same thing.
just to elaborate on nicks point, insert a trim plug, then automate its gain.
not as sexy, but same result. (just make sure its after any dynamics processors in the insert chain. if you're out of inserts, buss it to a sub mix aux and trim that automation.) b.o.l. e
ihatetyping |
PTX 10.1.1 Volume Trim Bug? | Cryos | macOS | 6 | 03-26-2012 09:40 PM |
trim volume pt 9 le? | papitopinillo | Pro Tools 9 | 14 | 08-25-2011 01:29 PM |
Trim vs Volume | Chief Pronto | Windows | 10 | 02-10-2011 07:24 AM |
7.2 Volume Trim | Ken P | Post - Surround - Video | 9 | 09-21-2006 10:54 AM |
volume trim | oilbedamned | Pro Tools TDM Systems (Mac) | 17 | 04-27-2006 05:33 AM |
