Old 10-28-2001, 08:50 PM
Philthy Philthy is offline
Default Re: Modifying the Minutes:Seconds Ruler
In the session setup window you can set the session start time. I've never tried setting it to a negataive value but from what you're saying I assume you can.
Phil Mann
Silk City Music Factory - CT Recording Studio
Old 10-29-2001, 12:03 AM
DJ Burt DJ Burt is offline
Default Modifying the Minutes:Seconds Ruler
I have done this before but can't, for the life of me, remember how to do it now. Does anyone know how to modify the Minutes:Seconds Ruler at the top of the Edit screen so that it shows negative values (say -0:10 for minus ten seconds) all the way up to zero and then carries on as normal?
Cheers,
[img]images/icons/smile.gif[/img]
dj
Old 10-29-2001, 08:55 AM
Mt.Everest Mt.Everest is offline
you have to drag your blue session start tempo icon to the right so the session dont start right at the top... So now bar 1 beat 1 will be into the session some... so everything to the left of it will be negative, including the min:sec ruler, until it gets to bar 1, and then it will count positive again.. and if your not using a grid or tempo map, then just hide that ruler and you will see the min:sec be negative nontheless
MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O
PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8
PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626
•••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!•
Old 10-30-2001, 12:40 AM
Cheers guys [img]images/icons/smile.gif[/img]
Dj
Set Minutes and seconds start time Dizzi45Z Pro Tools 10 15 06-14-2023 12:20 PM
computer randomly freezing for a few seconds to several minutes audiogeekzine Pro Tools M-Powered (Win) 2 09-30-2010 07:41 PM
Keyboard Key Modifying? Keith Moore Pro Tools TDM Systems (Mac) 2 11-01-2007 06:14 AM
Advice on modifying 888/24 interface Ian Greaves General Discussion 1 01-21-2000 07:58 AM
Modifying Volume & EQ across an Instrument TobinJames Digidesign Hardware & Software 0 04-29-1998 11:07 AM
