  #71
Old 06-08-2011, 03:28 PM
PTUser NYC PTUser NYC is offline
Default Re: how to avoid clipping on post fader bus sends?
Right Wild Honey. if he thinks reducing the volume affects his dynamic range, then he didn't read my long post about levels very carefully.
  #72
Old 06-08-2011, 04:00 PM
jacko's Avatar
jacko jacko is offline
Originally Posted by WildHoney View Post
FWIW, simply trimming down the levels of your tracks doesn't reduce your dynamic range. i.e. if the original range of your acoustic guitar track went from, say -50dBFS to -1dBFS, you have 49db of dynamic range in that track. If you trim it down -12db, your range is now -62dBFS to -13dBFS; still 49db of dynamic range.
The dynamic range of 24bit audio is 144dB. If you trim level down you loose information in the lower part of that range. I will agree that loosing some of that can be ignored, because noise level is always far higher than -144dBFS.
UAD Apollo x16,
UAD Apollo Twin Duo,
UAD Octo Thunderbolt,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Arturia Beastep for DAW control,
Former Pro Tools HD user (from V7 until V12.6).
  #73
Old 06-08-2011, 04:14 PM
WildHoney WildHoney is offline
Oy. . . .
  #74
Old 06-08-2011, 04:26 PM
jacko's Avatar
Oy. . . .
Of course if you talk about dynamic range in musical terms, as a difference between the loudest and the quietest parts of an instrument, you are absolutely right. I am talking about this definition of dynamic range:
http://en.wikipedia.org/wiki/Dynamic_range
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
  #75
Old 06-08-2011, 04:38 PM
Jacek, please reread my post about levels. Your signal has noise in it that is above the noise int he system. This is what you're missing. The dynamic range wont change if you trim 12db.
  #76
Old 06-08-2011, 04:41 PM
jacko's Avatar
I already said that in one of my previous posts, so I can't agree with you more :)
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
  #77
Old 06-09-2011, 01:47 AM
Rockpolice Rockpolice is offline
I don't see any reason not to run Pro Tools in the way it was designed to run.
From PT manual: Green indicates nominal levels; Yellow indicates pre-clipping. Where do they say you should run everything at pre-clipping levels?
Music business is serious business.
  #78
Old 06-09-2011, 02:53 AM
jacko's Avatar
Green indicates nominal levels; Yellow indicates pre-clipping (–6 dB below full scale); and Red indicates clipping.
yellow in ProTools 9 is 12dB below full scale, not 6dB
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
  #79
Old 06-09-2011, 03:48 AM
The meters on Logic - now THEY'RE a joke......
  #80
Old 06-16-2011, 03:06 AM
jacko's Avatar
Hit out at Dave Pensado. This guy must be completely hopeless to some of you!
http://youtu.be/jofMNLoyUZs
He doesn't have this mysterious hidden clipping, he's got the visible one!
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Automating Pre/Post Fader Sends Matthew Harrold Post - Surround - Video 8 11-27-2017 06:33 PM
Clipping of post fader sends in 6.4 burningbusch Pro Tools TDM Systems (Mac) 4 06-07-2011 08:01 AM
SENDS: Post/Pre-Fader which is better/most common? GapeOne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-24-2004 03:04 PM
Sends, pre-post fader? Tito Ricci Arballo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-22-2003 06:16 PM
Pre/Post fader aux sends not automated?!? DannyVanSpreuwel Pro Tools TDM Systems (Mac) 2 11-29-2000 10:45 AM
