Old 03-26-2003, 01:48 PM
Default Re: Using 888/24 and 888/16 Simultaneously
The original cable will work.. you use less DSP by using a Y cable.. make sure in your harware setup that it's an 888 and not an 888/24.. that's all there is to it.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 03-27-2003, 12:53 AM
Khaarmeyer Khaarmeyer is offline
Default Using 888/24 and 888/16 Simultaneously
I recently purchased a used 888/16 for it's digital in/outs with my mix cubed system.
Mix cubed w/ 888/24 on one card and 1622 on the other. One card empty.
What is the best way to attach the 888/16?
1. A splitter cable and connect the 888/16 and the 88/24 on one card?
OR
2. Connect the 888/16 to the empty card (will it take up an extra chip this way?
Also, do I need a new cable to attach the 888/16 to the mix3 system or will the original one work.
Any info would be appreciated.
Keith
Using the mic pre and rig output simultaneously via AES? Doctorgun Eleven Rack 6 10-06-2013 02:43 PM
Using 003 and 11R inputs simultaneously? 00011011 Eleven Rack 2 10-18-2010 08:48 PM
How many inputs simultaneously? Oroz Pro Tools TDM Systems (Mac) 10 07-16-2004 11:40 AM
Logic and PT simultaneously... Muzoid Pro Tools TDM Systems (Mac) 7 09-13-2003 10:55 AM
Can I use two 001's simultaneously? Moot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-14-2001 05:36 PM
