No solution to Xpand not finding it's files?
So I'm on PT12 on a Mac running Mavericks. Is there really no way to get Xpand2 to remember where the content files are? i've tried every solution found online, and the PT knowledge base basically says, "Yeah, that can happen for a couple of reasons. Sorry."
Anyone have any luck getting this to stop/ I'm so tired of, upon opening sessions, having to go and re-link Xpand to it's files, and then re-select all the patches for each instance. Just curious, Eric Last edited by EricWillhelm; 03-10-2016 at 11:55 AM. |
Re: No solution to Xpand not finding it's files?
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
Like reinstalling??
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey Alesis Masterlink, Alesis Adat LX20, , Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon, Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric. http://www.johnackermusic.com/ [email protected] Live and Let Live |
Tried reinstalling. Keeps happening.
Where are you telling the files to go? Are you letting it pick or are you picking?
Just brainstorming.
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey Alesis Masterlink, Alesis Adat LX20, , Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon, Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric. http://www.johnackermusic.com/ [email protected] Live and Let Live Last edited by SpinningDisk; 03-11-2016 at 01:02 PM. |
They're in the default location. And I keep pointing it to them, but as soon as you close PT and re-open, it forgets. So you have to re-link every time.
This pretty much sums it up. "However it can happen that the plugin doesn't "remember" the path to that file and prompts the user to locate it again and again."
http://avid.force.com/pkb/articles/e...actory-content |
Did you read this thread (post#37 and post #54) ? I posted lots of info so it can be a bit confusing (but detailed), but to sum up :
Try to find ALL *.plist files related to Xpand (ie : com.airmusictech.xpand.plist, com.digidesign.xpand!.plist, etc *) in both Mac OSX's Preferences files AND User's Preferences files, and check that each file does contain a location path for the library. If one of those doesn't have any path (or a wrong one), it is probably the culprit one. There might be lots reason for this issue but, for sure, one of those plist file is not correctly updated (either because of a wrong filename or because of bad permissions preventing Xpand2 to update this file). Anyway, with Maverick, you cannot edit a plist file directly, you must first copy the file on your desktop's folder, then edit it (with TextEdit or TextWrangler), copy it back to the correct Preferences folder (+enter your admin password), and reboot the mac. (Note : Pro Tools must be closed when you edit the plist file.) * filename's character case may be important depending if your system drive format is HFS+ Case-sensitive or Non-case-sensitive.
Macbook Pro (Core2duo 2,4GHz RAM4GB SSD) MacMini (Core i7 Quad@2,3GHz RAM16GB SSD) PT 10.3.10 + PT12.4 / VEP5.3.1 / MacOSX.9.5 (MBP) PT12.4 / VEP5.3.1 / MacOSX.11.1 (MBP) PT 10.3.10 / PT11.3.2 / PT12.4 / VEP5.3.1 / MacOSX.8.5 (MM "Production" on SSD) PT 12.4 / VEP5.3.1 / MacOSX.11.1 (MM "test" on HDD) RME UFX (USB2 with MM and Firewire with MBP) + Vienna Ensemble Pro Server on PC Q6600/8Gb/Win7-Pro64-SP1 Last edited by demodigi; 03-11-2016 at 03:13 AM. |
Thank you for this! I thought I saw a reply like this earlier yesterday, but then last night I couldn't find it! This seems like a hopefully promising solution! I'll try it shortly and let you know.
Solution for those having problems finding HDX in the Playback Engine | adrianrobison | Pro Tools HDX & HD Native Systems (Mac) | 4 | 07-24-2014 09:57 PM |
Finding Missing Files..please assist. | teacherman | Tips & Tricks | 6 | 02-15-2012 06:09 AM |
Finding saved files | johnny41 | Pro Tools SE and Essential (Win) | 0 | 02-12-2012 07:07 AM |
Short of finding an old mac (MLCD images))-Solution! | TCDet | Pro Tools TDM Systems (Mac) | 5 | 02-11-2008 10:02 AM |
Need help finding some good plug-ins like Xpand!. | Mboxer2 | General Discussion | 3 | 12-22-2007 08:50 AM |
