Old 11-09-2018, 07:12 PM
coleeddy coleeddy is offline
Default Rookie question about using an analog mixer
So i was given a 24 channel EVM4 mixing console from my brother. I have it in my studio and im just basically using it for master volume at the moment. I was watching a video earlier of Chris Lord Algae mixing a miranda lambert song and in the middle he was using one fader to turn up and the down the volume of the music and using other faders to turn up and down the vocals. So my question is how could I go about hooking my mixing console up to where I can use use one fader for the music and another fader for the vocals and use the Eq's on the board to edit the vocals?
(btw I have already panned the music to the left side and pan the vocals to the right side and could do it that way. After I use the eq's on the board to edit the vocal, I bounced out the song from pro tools and none of the eq's I did on the board was still on the song)
Old 11-09-2018, 07:32 PM
Default Re: Rookie question about using an analog mixer
You need to use Pro Tools just like a multi-track tape machine and feed line input to each track (for mixing and out each track if you are tracking live through the console) and record the main bus, or whatever other bus you want. Lots of books on audio engineering will talk about doing that. If like your profile shows you have a 2x2 interface, you cannot even start, to use the full console you would need a 24x26 (or more) interface, worth well more than the console itself (even to partially use the console, the interface needed is likely to cost you more than the console is worth).
But uh what is this? An Elecro Voice mixer.... likely not worth much and will sound worse than mixing ITB, and you can’t automate the mixer or use it as a control surface... so why bother? I’d maybe put it aside and use for band practice etc. If you want a control surface start by looking at the Avid S3, if you really want to mix OTB that will sound great... what is your budget ?
Analog mixer front end question. Terry Wetzel General Discussion 14 10-02-2015 03:15 PM
Rookie Question nexty76 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-31-2010 09:17 PM
analog mixer + control surface = digital mixer? j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 10-11-2006 05:12 AM
Help! rookie question, but pls help! dkrz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-04-2003 12:02 AM
really rookie question 18Duffs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-11-2002 04:33 PM
